    Unhappy Slack12 + squid 2.6 encrencando
    Galera instalei o slack 12 aki e o squid 2.6 em proxy transperente pra 30 clientes simultâneos só que umas 3 vezes por dia não dá pra acessar nada na internet, ai eu reinicio o squid e tudo volta, isso não acontecia no slack 11, esses problemas começaram quando eu migrei pro 12, o que deve ser?
    Meu server tem 1.2 GB de RAM e 2.5 de Procesador
    veja o /var/log/squid/cache.log
    poste suas confs do squid.. talvez o squid esteja sacrificando a maquina :P
    Kra verificando o cache.log eu notei algumas coisas estranhas:
    Código :
    2007/08/01 16:56:17| parseHttpRequest: Requestheader contains NULL characters
    2007/08/01 16:56:17| parseHttpRequest: Unsupported method '.².ÌKb*#!IPñE^G.¬n»^H^N/Õ'
    2007/08/01 16:56:17| clientReadRequest: FD 29 (192.168.0.15:2966) Invalid Request
    2007/08/01 16:58:28| parseHttpRequest: Unsupported method '.¼ë@
    2007/08/01 16:58:28| clientReadRequest: FD 20 (192.168.0.15:3027) Invalid Request
    2007/08/01 16:59:06| parseHttpRequest: Unsupported method 'ý.Ï-A_^APT©^O¼.&^L&yÙrw^K^Y^E~^YW`õÒÌ^W0^?è
    2007/08/01 16:59:06| clientReadRequest: FD 20 (192.168.0.15:3046) Invalid Request
    2007/08/01 16:59:08| parseHttpRequest: Unsupported method '.Sr®G`F
    2007/08/02 12:17:45| Ready to serve requests.
    2007/08/02 12:17:45| Store rebuilding is  7.3% complete
    2007/08/02 12:17:46| WARNING: newer swaplog entry for dirno 0, fileno 00000010
    2007/08/02 12:17:46| WARNING: newer swaplog entry for dirno 0, fileno 00000011
    2007/08/02 12:17:46| WARNING: newer swaplog entry for dirno 0, fileno 00000012
    O que é isso?
    Ai vai o meu squid.conf....
    Código :
    #       WELCOME TO SQUID 2.6.STABLE5
    http_port 192.168.0.1:8080 transparent
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
     cache_mem 100 MB
     maximum_object_size 9000 KB
    cache_dir ufs /var/cache/squid 1000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    refresh_pattern ^ftp:           1440    20%     10080
    refresh_pattern ^gopher:        1440    0%      1440
    refresh_pattern .               0       20%     4320
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443
    acl Safe_ports port 80          # http
    acl Safe_ports port 21          # ftp
    acl Safe_ports port 443         # https
    acl Safe_ports port 70          # gopher
    acl Safe_ports port 210         # wais
    acl Safe_ports port 1025-65535  # unregistered ports
    acl Safe_ports port 280         # http-mgmt
    acl Safe_ports port 488         # gss-http
    acl Safe_ports port 591         # filemaker
    acl Safe_ports port 777         # multiling http
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow all
    http_reply_access allow all
    icp_access allow all
    cache_effective_user proxy
    cache_effective_group proxy
    visible_hostname Server
    error_directory /usr/local/squid/share/errors/Portuguese
    coredump_dir /var/cache/squid
    estes warnings:
    lientReadRequest e parseHttpRequest... sao normais.. sao programas P2P que tentam usar a porta 80 para comunicar, mas como o squid somente suporta o protocolo HTTP, da esses erros ai..
    sobre o erro..
    vendo ai o cache.log, parece que o processo do seu squid esta sendo "morto" por algum comando KILL (ou pelomenos esta sendo forçado a terminar).
    um erro ai na sua conf.. o seu cache_mem esta alto.. abaixa ele para 32mb !!!
    seu squid esta aberto para relay.. crie uma acl assim:
    acl rede src 192.168.0.0/24
    e TROQUE o http_addres allow all por http_access deny all
    e antes dele adicione http_access allow rede
    sobre o erro, veja se existem arquivos core dentro do /var/cache/squid
    se tiver, execute isto:
    gdb /usr/sbin/squid /var/cache/core.313123
    /usr/sbin/squid é o binario do squid, veja onde esta o do seu sistema...
    core.313123 eh o arquivo de dump que o squid gerou...
    ai ele vai mostrar umas libs etc etc.. tu digita where
    e posta aqui o que o comando gdb mostrou...
    Veja a saída:
    ls /var/cache/squid/
    00/ 01/ 02/ 03/ 04/ 05/ 06/ 07/ 08/ 09/ 0A/ 0B/ 0C/ 0D/ 0E/ 0F/ swap.state
    Num tem arquivos core ai nao neh...
    e no diretorio onde esta o squid.conf ?
    ls /etc/squid/
    cachemgr.conf mime.conf mime.conf.default squid.conf* squid.conf.default
    Veja o erro exato que dá qd ele trava:
    Código :
     A URL solicitada não pode ser recuperada
    Na tentativa de recuperar a URL: https://under-linux.org/
    O seguinte erro foi encontrado:
        Incapaz de determinar o endereço IP através do nome do host www.under-linux.org
    O servidor DNS retornou:
        Timeout
    Isso significa que:
     O cache foi incapaz de resolver o nome do host presente na URL.
     Verifique se o endereço está correto.
    Isso geralmente acontece qd muitos usuários se conectam simultaneamente.
    ja tentou ver se acontece algo parecido quando esta sem squid ?
    Sem o squid funciona tudo perfeitamente, e o squid só trava quando a quantidade de acessos simultaneos é acima de 40
    troca isso:
    Código :
    por isso
    Código :
    cache_dir diskd /var/cache/squid 1000 16 256 Q1=72 Q2=64
    ufs eh otimo para pequenos proxies, de até 5 requisicoes por segundo.. se sao 40 usuarios simultaneamente.. com certeza voce deve ter uns 10 requests por segundo...
    Deu o seguinte erro:
    FATAL: Bungled squid.conf line 144: cache_dir diskd /var/cache/squid 1000 16 256 Q1=72 Q2=64
    Squid Cache (Version 2.6.STABLE5): Terminated abnormally.
    O que eu acho mais engraçado é que com essa mesma configuração e nessa mesma condição de requisições ele funcionava perfeito, foi só colocar o slack 12 ele começou a bugar...
    netobarros
    ola amigos!!
    Aqui no meu squid.conf eu uso Q1=64 e Q2=72
    Essa é a configuração padrão neh, coloquei aqui e ta rodando direitinho!!
    cache_dir diskd /cache 55000 32 512 Q1=64 e Q2=72
    pode ser feito assim?
    valews
    Você tem certeza que o diskd está instalado no seu Linux ?
    nao recomendo voce usar o L2 em 512.. 256 eh um tamanho otimizado
    para cache de 55GB .. use o L1 em 48 e L2 em 256
    netobarros
    amigo eu creio q sim!!!
    quando digito top ele aparece la, juntamente com squid e o RunCache&
