Página 13 de 13 PrimeiroPrimeiro ... 8910111213
    Eita... acho q conseguimos...
    Adicionei algumas regras além das que estao no Load Balancing - MikroTik Wiki
    e aparentemente funcionou... tah segurando a conexao com o banco do brasil...
    Minha config ficou assim:
    Código :
    / ip dns
    set primary-dns=201.10.128.2 secondary-dns=201.10.1.2 \
        allow-remote-requests=yes cache-size=2048KiB cache-max-ttl=1w
    / ip address
    add address=192.168.1.254/24 network=192.168.1.0 broadcast=192.168.1.255 \
        interface=local comment="" disabled=no
    add address=172.16.1.1/24 network=172.16.1.0 broadcast=172.16.1.255 \
        interface=link1 comment="" disabled=no
    add address=172.16.2.1/24 network=172.16.2.0 broadcast=172.16.2.255 \
        interface=link2 comment="" disabled=no
    / ip firewall mangle
    add chain=prerouting in-interface=local dst-address=170.66.11.0/24 \
        connection-state=new action=mark-connection new-connection-mark=banco \
        passthrough=yes comment="" disabled=no
    add chain=prerouting in-interface=local dst-address=170.66.2.0/24 \
    add chain=prerouting in-interface=local connection-mark=banco \
        action=mark-routing new-routing-mark=banco passthrough=no comment="" \
        disabled=no
    add chain=prerouting in-interface=local connection-state=new nth=1,1,0 \
        action=mark-connection new-connection-mark=odd passthrough=yes comment="" \
        disabled=no
    add chain=prerouting in-interface=local connection-mark=odd \
        action=mark-routing new-routing-mark=odd passthrough=no comment="" \
        disabled=no
    add chain=prerouting in-interface=local connection-state=new nth=1,1,1 \
        action=mark-connection new-connection-mark=even passthrough=yes comment="" \
        disabled=no
    add chain=prerouting in-interface=local connection-mark=even \
        action=mark-routing new-routing-mark=even passthrough=no comment="" \
        disabled=no
    / ip firewall nat
    add chain=srcnat connection-mark=banco action=src-nat to-addresses=172.16.1.1 \
        to-ports=0-65535 comment="" disabled=no
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=172.16.1.1 \
    add chain=srcnat connection-mark=even action=src-nat to-addresses=172.16.2.1 \
    / ip route
    add dst-address=0.0.0.0/0 gateway=172.16.1.254 scope=255 target-scope=10 \
        routing-mark=odd comment="" disabled=no
    add dst-address=0.0.0.0/0 gateway=172.16.2.254 scope=255 target-scope=10 \
        routing-mark=even comment="" disabled=no
        routing-mark=banco comment="" disabled=no
    Tenho ainda algumas duvidas...
    Tenho 2 links de 1mb nesta maquina em baixo da torre fazendo este load... em cima da torre tenho 1 maquina com 4 wlans e 1 lan...
    No grafico da lan q vai pra torre o trafego nao passa de 900kb... nao deveria chegar a pelo menos 1800kb agora q to com 2 links?
    Vlw..
  2. #74
    Como esta a coisa ai?
    na maquina de baixo, 2 LAN recebendo o link e 1 lan mandando para cima, certo?
    Veja no grafico das 2 lan´s de entrada, em qto estão..
    e na LAN que manda lá para cima tem que ter +- a soma das 2 entradas
    aproximadamente
  3. #75
    Citação Postado originalmente por liandrocarniel Ver Post
    aproximadamente
    É exatamente assim que está... e a lan q manda pra cima tah dando a soma das duas q recebem os links... porem nao passa de 900k sendo q tenho 2 links de 1mb...
  4. #76
    Isso é bom.. que teus usuários não estão usando muito...eheheh
    Se na saida está dando a soma, então tem que ver se os teus adsl´s estão funcionando 100%
    Não tem como saber qual o problema ai. Teste individualmente.
    Obs.: ADSL não tem garantia de banda (ou melhor, tem garantia de 10%)
  5. #77
    Os adsl estao bons... eu monitoro o log deles... jah ficou mais de 160 horas sem cair... varias vezes no dia eu testo a velocidade... sempre dah em torno de 700 a 900k...
    Tava pensando.. acho q a lan q manda pra cima nao vai passar dos 900k, pq o que tah sendo feito eh o balanceamento dos links e nao a soma das velocidades, nao seria isso?
    Por exemplo.. se eu tivesse 10 links de 1 mb.... a lan q manda pra cima marcaria 900k, e os clientes todos seriam balanceados nesses 10 links?
    Veja bem... qdo eu tinha apenas 1 link, eu tinha 50 clientes cadastrados... e funcionava legal... agora, fazendo este loadbalance, serah q posso colocar 100 clientes sem medo?
    Abraços..
  6. #78
    Olá pessoal... seguinte....
    Como faço para acessar externamente meu mikrotik sendo q tenho esta outra maquina com mikrotik fazendo load balance?
    Tenho q redirecionar portas? como faço isso?
    Obrigado...
