    Thumbs down link pela mesma interface dos usuarios
    estou tomando uma surra para fazer funcionar o meu loadbalance, a rede está assim link1<==>mk<==>radio<==(clientes+link2)
    mas n consigo fazer o mk rediriconar nada para o link 2 gostaria da ajuda de vcs, pois ja fiz de tudo e nada funciona.
    configs:
    modem(link1)bridge
    mk:192.168.1.2
    radio(sai para os clientes e entra o link 2): 192.168.1.1
    link2:192.168.1.7
    fico no aguardo da ajuda de vcs e obrigado pela atenção!
    minhas regras de router:
    Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf
    # DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
    0 ADC 192.168.1.0/24 192.168.1.2 rede
    1 ADC 200.217.72.22/32 201.19.122.2 velox
    2 A S 0.0.0.0/0 r 192.168.1.7 rede
    3 AD 0.0.0.0/0 r 200.217.72.22 1 velox
    minhs regras de mangle:
    Flags: X - disabled, I - invalid, D - dynamic
    0 ;;; Marca conexoes na porta 21 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=21 action=mark-routing new-routing-mark=link2 passthrough=no
    1 ;;; Marca conexoes na porta 22 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=22 action=mark-routing new-routing-mark=link2 passthrough=no
    2 ;;; Marca conexoes na porta 23 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=23 action=mark-routing new-routing-mark=link2 passthrough=no
    3 ;;; Marca conexoes na porta 25 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=25 action=mark-routing new-routing-mark=link2 passthrough=no
    4 ;;; Marca conexoes na porta 53 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=53 action=mark-routing new-routing-mark=link2 passthrough=no
    5 ;;; Marca conexoes na porta 53 c/ a marca link2 - by Antoni
    chain=prerouting protocol=udp dst-port=53 action=mark-routing new-routing-mark=link2 passthrough=no
    6 ;;; Marca conexoes na porta 80 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=80 action=mark-routing new-routing-mark=link2 passthrough=no
    7 ;;; Marca conexoes na porta 110 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=110 action=mark-routing new-routing-mark=link2 passthrough=no
    8 ;;; Marca conexoes na porta 443 c/ a marca link2 - by Antoni
    chain=prerouting protocol=tcp dst-port=443 action=mark-routing new-routing-mark=link2 passthrough=no
    9 ;;; Marca pacotes c/ a marca link2 - by Antoni
    chain=prerouting routing-mark=link2 action=mark-packet new-packet-mark=link2 passthrough=no
    10 chain=prerouting p2p=all-p2p action=mark-connection new-connection-mark=p2p_conn passthrough=yes
    11 chain=prerouting connection-mark=p2p_conn action=mark-packet new-packet-mark=p2p passthrough=yes
    minhas regras de de nat:
    0 chain=srcnat out-interface=velox action=masquerade
    1 chain=dstnat in-interface=rede protocol=tcp dst-port=80 action=redirect to-ports=3128
    2 ;;; masquerade hotspot network
    chain=srcnat src-address=192.168.1.0/24 action=masquerade
    obs: tem algumas regras em nat e mangle q sao do hotspot mas q n consegui dar print pq sao dinamicas!
    Eu pelo menos nunca consegui faz NAT para a mesma interface de rede... Acho que você vai ter q colocar outra placa de rede para o link nesse mikrotik q tem os clientes...
    Padrão nat na mesma interface
    aqui eu fiz sem problemas, criei um ap virtual, coloquei ip e fiz o nat, belza,
    qualquer dúvida [email protected]
    aqui eu uso um radio e o mk esta só como server ai n tem como eu criar um ap virtual! mas vlw pela dica!
