- Proxy Transparente
Proxy Transparente
Olá! Hoje aqui na empresa em que trabalho fiz um Proxy transparente squid, mas ele nao pede autentificação de jeito ou maneira! Ai esta minha configuração:
http_port 3128 transparent
hierarchy_stoplist cgi-bin ?
cache deny QUERY
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
client_netmask 255.255.255.0
auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/squid_passwd
auth_param basic realm Acesso_Monitorado
visible_hostname SVR
auth_param basic children 5
auth_param basic credentialsttl 1 hours
auth_param basic casesensitive off
refresh_pattern . 0 20% 4320
acl all src 0.0.0.0/0.0.0.0
acl Safe_ports port 21 # ftp
acl Safe_ports port 80 # http
acl Safe_ports port 443 # https
acl Safe_ports port 631 # cups
acl Safe_ports port 873 # rsync
acl SSL_ports port 443 # https
acl SSL_ports port 465 # YAHOO - SMTP (SSL)
acl SSL_ports port 563 # snews
acl SSL_ports port 873 # rsync
acl SSL_ports port 995 # YAHOO - POP3 (SSL)
acl purge method PURGE
acl CONNECT method CONNECT
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
http_access allow localhost
http_access deny to_localhost
acl rede_interna src 192.168.10.0/24
acl usuarios proxy_auth REQUIRED
acl acesso_livre proxy_auth "/etc/squid/listas/usr_livre"
http_access allow acesso_livre
acl acesso_restrito proxy_auth "/etc/squid/listas/usr_restrito"
acl url_bloqueado url_regex -i "/etc/squid/listas/url_bloqueado"
http_access deny url_bloqueado
http_access allow acesso_restrito !url_bloqueado
acl acesso_bloqueado proxy_auth "/etc/squid/listas/usr_bloqueado"
acl url_liberado url_regex -i "/etc/squid/listas/url_liberado"
http_access allow url_liberado
http_access deny acesso_bloqueado !url_liberado
http_access allow usuarios acesso_livre
http_access allow usuarios acesso_restrito
http_access allow usuarios acesso_bloqueado
http_access deny !rede_interna
http_access allow rede_interna
http_access deny all
icp_access allow all
Se alguem puder ajudar agradeço!
Lucas.
re: Proxy Transparente
Amigo, voce mesmo já respondeu sua duvida.
"Proxy transparente squid" não tem autenticação. É transparente (o usuario nao sabe que esta atras de um proxy).
Obrigado!
Como eu faria para aparecer a autenticação tem jeito?
Script para squid 2.6
Faça o download o squid.conf.
squid.conf.zip
Avisos:
- Lembre de alterar o campo 192.168.1.0/255.255.255.0 para o range de ips da sua rede interna
- Lembre de alterar no campo ips_sem_senha para os ips que vc queira que não utilizem proxy
- Lembre de alterar o seu visible_hostname
- Lembre de alterar/incluir/excluir os grupos que quiser
Agora criaremos os arquivos de grupos e de sites.
Digite na sua shell:
# mkdir /etc/squid/grupos
# mkdir /etc/squid/regras
# cd /etc/squid/grupos
# touch diretoria
# touch informatica
# touch financeiro
# touch administrativo
Agora você tem que adicionar usuários em todos arquivos de grupos:
Ex: vi diretoria
#Digite o nome do usuarios
Feito isso agora cadastre uma senha para o usuario
htpasswd passwd diretoria01
Siga o scrip do squid e veja o arquivos que tem que serem criados e adicione bloqueios e liberados. Lembrando que todos os arquivos tem que criados e deve conter pelo menos um caractere.
Ex: touch /etc/squid/regras/sites_liberados_informatica
