- ag530 help
ag530 help
estou com um problema com ag530....elas dao pings de 1ms de repente sobe pra 150ms e depois volta pra 1ms...(sem trafego nela)...ai vai as conf
0 R name="b3c3" mtu=1500 mac-address=00:13:46:9B:A6:10 arp=reply-only disable-running-check=no
interface-type=Atheros AR5413 radio-name="SGNetWLsSb3c3" mode=ap-bridge ssid="SGNetWLsSb3c3" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default
rate-set=configured supported-rates-b=11Mbps supported-rates-a/g="" basic-rates-b=11Mbps basic-rates-a/g=""
max-station-count=2007 ack-timeout=dynamic tx-power=22 tx-power-mode=all-rates-fixed noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a
wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=no default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
1 R name="b3c4" mtu=1500 mac-address=00:13:46:9B:A6:25 arp=reply-only disable-running-check=no
interface-type=Atheros AR5413 radio-name="SGNetWLsSb3c4" mode=ap-bridge ssid="SGNetWLsSb3c4" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2452 band=2.4ghz-b scan-list=default
2 R name="b3c5" mtu=1500 mac-address=00:13:46:9B:19:E9 arp=reply-only disable-running-check=no
interface-type=Atheros AR5413 radio-name="SGNetWLsSb3c5" mode=ap-bridge ssid="SGNetWLsSb3c5" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2427 band=2.4ghz-b scan-list=default
3 R name="b3c2" mtu=1500 mac-address=00:13:46:9A:A0:2E arp=reply-only disable-running-check=no
interface-type=Atheros AR5413 radio-name="SGNetWLsSb3c2" mode=ap-bridge ssid="SGNetWLsSb3c2" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2442 band=2.4ghz-b scan-list=default
me ajudem por favor
Ja testou com preamble em long ?
E o data rate em default ?
Boa Sorte.
Fabricio Chicon
Freenetworks Soluções em Informática Ltda.
Porto Alegre ,RS
51-33615038
sim nao mundou muito nao...melhorou..mais mesmo assim continuo o problema
Ag530 help
Tenho enlaces com 3 repetidores e varios clientes pelo meio do caminho
tenho algumas dicas que podem resolver a questao
periodic-calibration=enable
ou calcular o ack pelo cliente mais longe.
Obstaculos tambem podem alterar temporariamente o valor do ping.
(travessia de rodovia antenas abaixo do relevo)
espero ter ti ajudado...
DAVIRADIO
