- Config. do AP2000BG
Config. do AP2000BG
Pessoal, comprei um AP2000BG com Cartão Silver, porque o que venho nele não funfa mesmo, o tal do cartão que funciona tanto para "b" como para "g".
Gostaria que alguém que tivesse um AP2000 em provedor, me desse uma dica para melhor desempenho deste AP, pois existem recursos que não utilizo, porque não sei a finalidade, segue abaixo a configuração do mesmo:
INTERFACES: (Card A)
Frequency Channel : 6
Distance Between APs: Large
Multicast Rate: 2Mbit/s
DTIM Period (1-255 ): 1
RTS/CTS Medium Reservation (2347=off):2347
Enable Interference Robustness: Ativado
Enable Closed System: Desativado
Enable Load Balancing: Ativado
Enable Medium Density Distribution: Ativado
FILTERING - Ethernet Protocol
Ethernet Protocol Filtering:All Interfaces
Filter Operation Type: Block
80:19 Apollo Domain Enable
80:9B Apple Talk 1 and 2 Enable
80:F3 Apple Talk ARP 1 and 2 Enable
0B:AD Banyan VINES Enable
0B:AF Banyan VINES Echo Enable
60:03 Decnet Phase IV Enable
60:05 DEC Diagnostic Enable
60:04 DEC LAT Enable
60:07 DEC LAVC Enable
60:01 DEC MOP Dump/Load Enable
60:02 DEC MOP Rem Cons Enable
80:40 DEC NetBIOS Enable
80:05 HP Probe Control Enable
80
5 IBM SNA Services Enable
08:00 IP Disable
08:06 IP-ARP Disable
81:37 Novell(ECONFIG E) Enable
80:35 RARP Reverse ARP Enable
81:4C SNMP Over Ethernet Enable
08:88 Xyplex Enable
FILTERING - Advanced
Enable Proxy ARP : Desativado
Enable IP/ARP Filtering : Desativado
FILTERING - TCP/UDP Port
Enable TCP/UDP Port Filtering : Ativado
NetBios Name Service 137 TCP/UDP All Interfaces Enable
NetBios Datagram Service 138 TCP/UDP All Interfaces Enable
NetBios Session Service 139 TCP/UDP All Interfaces Enable
DCE endpoint resolution 135 TCP/UDP All Interfaces Enable
Microsoft-DS 445 TCP/UDP All Interfaces Enable
RPC Over HTTP 593 TCP/UDP All Interfaces Enable
BlackJack 1025 TCP/UDP All Interfaces Enable
ipx 213 TCP/UDP All Interfaces Enable
BRIDGE - spanning tree
Enable Spanning Tree Protocol: Ativado
Bridge Priority (0-65535) : 32768
Max Age (600-4000 1/100 sec) : 2000
Hello Time (100-1000 1/100 sec) : 200
Forward Delay (400-3000 1/100 sec) : 1500
Port Priority Path Cost State Status
1 128 100 Forwarding Enabled
2 128 100 Forwarding Enabled
3 128 100 Disabled Enabled
4 128 100 Disabled Enabled
5 128 100 Disabled Enabled
6 128 100 Disabled Enabled
7 128 100 Disabled Enabled
8 128 100 Disabled Enabled
9 128 100 Disabled Enabled
10 128 100 Disabled Enabled
11 128 100 Disabled Enabled
12 128 100 Disabled Enabled
13 128 100 Disabled Enabled
14 128 100 Disabled Enabled
15 128 100 Disabled Enabled
BRIDGE - Storm Threshold
Desativado
BRIDGE - Intra-BSS
Intra BSS Traffic Operation=Block
BRIDGE - Pkt Fwd
Desativado
Obs: Utilizo controle por MAC, não uso WEP e Autenticação.
Este AP tem 50 clientes, com velocidades variadas de 64 a 256 kbps
Se alguém me der uma luz nisso aí, ficarei muito grato.
Config. do AP2000BG
Ola amigo uso ap 2000 com cartões proxim b/g normalmente (atualise sua firmware) bem a única diferença entre nossos aps é que eu destivo o Load Balance. de resto o meu aqui funfa legal com 200 clientes pendurado em um cartão
Re: Config. do AP2000BG
200 clientes em 1 cartão como esta fazendo isso?? não tenho 90 em um cartão e fica horrivel quando estão todos conectados como é a sua rede configuração de micro pode nos dar maiores detalhes???
