Este já é o 3º topico que coloco pois ninguem quer me ajudar...sei que tem gente muito mais capacitada do que eu neste forum...
sei que algumas pessoas já passaram por esse problema, quero saber como resolver....
o Processo é: freeradius 2.x.x e mikrotik hotspot??? como fazer ???
pq mesmo instalando o freeradius do repositorio com um apt-get install freeradius-mysql, mas logo
apos a instalação se der um "freeradius -X" da este erro:
Failed binding to socket: Address already in use
/etc/freeradius/radiusd.conf[235]: Error binding to port for 0.0.0.0 port 1812
esse mesmo erro da no ubuntu 8.10 , 9.04 e debian 5...
se vc ir no radiusd.conf e descomentar user e group e der novamente um "freeradius -X"
ele da assim : Mas mesmo assim não funciona .
root@provebuntu:~# freeradius -X
FreeRADIUS Version 2.1.0, for host i486-pc-linux-gnu, built on Apr 30 2009 at 07:22:56
Copyright (C) 1999-2008 The FreeRADIUS server project and contributors.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License v2.
Starting - reading configuration files ...
including configuration file /etc/freeradius/radiusd.conf
including configuration file /etc/freeradius/proxy.conf
including configuration file /etc/freeradius/clients.conf
including files in directory /etc/freeradius/modules/
including configuration file /etc/freeradius/modules/mschap
including configuration file /etc/freeradius/modules/realm
including configuration file /etc/freeradius/modules/pap
including configuration file /etc/freeradius/modules/files
including configuration file /etc/freeradius/modules/sradutmp
including configuration file /etc/freeradius/modules/attr_rewrite
including configuration file /etc/freeradius/modules/expr
including configuration file /etc/freeradius/modules/preprocess
including configuration file /etc/freeradius/modules/ippool
including configuration file /etc/freeradius/modules/radutmp
including configuration file /etc/freeradius/modules/mac2vlan
including configuration file /etc/freeradius/modules/always
including configuration file /etc/freeradius/modules/sql_log
including configuration file /etc/freeradius/modules/inner-eap
including configuration file /etc/freeradius/modules/smbpasswd
including configuration file /etc/freeradius/modules/policy
including configuration file /etc/freeradius/modules/digest
including configuration file /etc/freeradius/modules/exec
including configuration file /etc/freeradius/modules/passwd
including configuration file /etc/freeradius/modules/acct_unique
including configuration file /etc/freeradius/modules/attr_filter
including configuration file /etc/freeradius/modules/pam
including configuration file /etc/freeradius/modules/mac2ip
including configuration file /etc/freeradius/modules/checkval
including configuration file /etc/freeradius/modules/linelog
including configuration file /etc/freeradius/modules/detail
including configuration file /etc/freeradius/modules/etc_group
including configuration file /etc/freeradius/modules/logintime
including configuration file /etc/freeradius/modules/unix
including configuration file /etc/freeradius/modules/counter
including configuration file /etc/freeradius/modules/ldap
including configuration file /etc/freeradius/modules/expiration
including configuration file /etc/freeradius/modules/detail.example.com
including configuration file /etc/freeradius/modules/krb5
including configuration file /etc/freeradius/modules/echo
including configuration file /etc/freeradius/modules/detail.log
including configuration file /etc/freeradius/modules/chap
including configuration file /etc/freeradius/modules/wimax
including configuration file /etc/freeradius/eap.conf
including configuration file /etc/freeradius/sql.conf
including configuration file /etc/freeradius/sql/mysql/dialup.conf
including configuration file /etc/freeradius/sql/mysql/counter.conf
including configuration file /etc/freeradius/policy.conf
including files in directory /etc/freeradius/sites-enabled/
including configuration file /etc/freeradius/sites-enabled/default
including configuration file /etc/freeradius/sites-enabled/inner-tunnel
group = radius
freeradius: Cannot get ID for group radius: Success
root@provebuntu:~#
por isso peço encarecidamente a ajuda de alguem, pois so falta isso pra eu poder tocar meu projetinho.." POR FAVOR ALGUEM, SERGIO, ALEXANDRE CORREA...ALGUEM..QUALQUER UM"
