- OPENLDAP+OPENSSL+FREEBSD
BOM VAMOS LA...
TO TENTANDO RODAR LDAP AQUI NO SERVER MAS ESTOU COM ALGUNS PROBLEMAS...
RODANDO O OPENSSL openssl-stable-0.9.7i o openldap roda que eh uma bleza... mas dai vem a necessidade de utilizar o openssl-0.9.8a por causa do mod_ssl do phpldapadmin e outros que precisam do openssl-0.9.8a.
ai q fica o problema na hora de testar a conexao jah de cara da este erro
openssl s_client -connect teste:636 -showcerts -state -CAfile /etc/ssl/ca.pem
SSL_connect:SSLv3 read server certificate A
SSL_connect:SSLv3 read server certificate request A
SSL_connect:SSLv3 read server done A
SSL_connect:SSLv3 write client certificate A
SSL_connect:SSLv3 write client key exchange A
SSL_connect:SSLv3 write change cipher spec A
SSL_connect:SSLv3 write finished A
SSL_connect:SSLv3 flush data
SSL3 alert read:fatal:handshake failure
SSL_connect:failed in SSLv3 read finished A
14146:error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure:/usr/src/secure/lib/libssl/../../../crypto/openssl/ssl/s3_pkt.c:1052:SSL alert number 40
14146:error:140790E5:SSL routines:SSL23_WRITE:ssl handshake failure:/usr/src/secure/lib/libssl/../../../crypto/openssl/ssl/s23_lib.c:226:
ai seu eu volto para a versao anterior do openssl tudo funciona normal!
ajuda!
