Desculpem o post sobre BSD aqui no geralops: , mas tentei no forum BSD sem sucesso, acho que nao tem muita gente passando por la... hehehehe
Estou tentando instalar o Clamav + MailScanner + Sendmail em FreeBSD-4.6.2, porem estou com um problema serio quanto a carga do servico que integra o clamav com o sendmail, na documentacao diz que e necessario o modulo "dazuko" carregado, e outro topico ja me ajudou em relacao a isso mas quando vou iniciar o Clamav, como usuario clamav, consulto o log que tem a seguinte mensagem:
Mon Jul 5 18:24:34 2004 -> +++ Started at Mon Jul 5 18:24:34 2004
Mon Jul 5 18:24:34 2004 -> clamd daemon 0.74 (OS: freebsd4.6.2, ARCH: i386, CPU: i386)
Mon Jul 5 18:24:34 2004 -> Log file size limited to 2097152 bytes.
Mon Jul 5 18:24:34 2004 -> Verbose logging activated.
Mon Jul 5 18:24:34 2004 -> Reading databases from /usr/local/share/clamav
Mon Jul 5 18:24:34 2004 -> Protecting against 22478 viruses.
Mon Jul 5 18:24:35 2004 -> Unix socket file /var/clamav/clamd
Mon Jul 5 18:24:35 2004 -> Setting connection queue length to 15
Mon Jul 5 18:24:35 2004 -> Listening daemon: PID: 1538
Mon Jul 5 18:24:35 2004 -> Archive: Archived file size limit set to 10485760 bytes.
Mon Jul 5 18:24:35 2004 -> Archive: Recursion level limit set to 5.
Mon Jul 5 18:24:35 2004 -> Archive: Files limit set to 1000.
Mon Jul 5 18:24:35 2004 -> Archive: Compression ratio limit set to 200.
Mon Jul 5 18:24:35 2004 -> Archive support enabled.
Mon Jul 5 18:24:35 2004 -> RAR support disabled.
Mon Jul 5 18:24:35 2004 -> Mail files support disabled.
Mon Jul 5 18:24:35 2004 -> OLE2 support enabled.
Mon Jul 5 18:24:35 2004 -> Self checking every 3600 seconds.
Mon Jul 5 18:24:35 2004 -> ERROR: Clamuko: Can't register with Dazuko
e ao executar kldstat o retorno e o seguinte :
bash-2.05a$ kldstat
Id Refs Address Size Name
1 3 0xc0100000 2f1d2c kernel
2 1 0xc10c7000 2000 snake_saver.ko
3 1 0xc1294000 a000 dazuko.ko
bash-2.05a$
nao sei o que posso estar fazendo de errado e nao tenho muita experiencia em FreeBSD, comecei a pouco tempo por isso peço a ajuda de vcs...
obs : se o mesmo erro acontece se tentar iniciar o clamav como root...
Valew
