caro colegas estou tendo este problema que nao to conseguindo resolve !!
intalei o mysql verifiquei e ele esta la na pasta /usr/local/mysql
so que quando tento criar a tabela da esta seguinte menssagem
root@serverzone:/usr/local/mysql# scripts/mysql_install_db --force
scripts/mysql_install_db: line 1: ./bin/my_print_defaults: cannot execute binary file
Installing all prepared tables
scripts/mysql_install_db: line 1: ./bin/mysqld: cannot execute binary file
./bin/mysql_create_system_tables: line 663: 12850 Broken pipe cat <<END_OF_DATA
use mysql;
set table_type=myisam;
$c_d
$i_d
$c_h
$i_h
$c_u
$i_u
$c_f
$i_f
$c_t
$c_c
$c_ht
$c_hc
$c_hr
$c_hk
$c_tzn
$i_tzn
$c_tz
$i_tz
$c_tzt
$i_tzt
$c_tztt
$i_tztt
$c_tzls
$i_tzls
END_OF_DATA
Installation of system tables failed!
Examine the logs in ./data for more information.
You can also try to start the mysqld daemon with:
./bin/mysqld --skip-grant &
You can use the command line tool
./bin/mysql to connect to the mysql
database and look at the grant tables:
shell> ./bin/mysql -u root mysql
mysql> show tables
Try 'mysqld --help' if you have problems with paths. Using --log
gives you a log in ./data that may be helpful.
The latest information about MySQL is available on the web at
http://www.mysql.com
Please consult the MySQL manual section: 'Problems running mysql_install_db',
and the manual section that describes problems on your OS.
Another information source is the MySQL email archive.
Please check all of the above before mailing us!
And if you do mail us, you MUST use the ./bin/mysqlbug script!
estou querendo colocar o phpmyadmin para rodar e dependo disso !!
grato
