no /var/log/messages tá assim:
May 12 07:40:02 caught syslogd 1.4.1: restart.
May 12 07:40:02 caught syslog: syslogd startup succeeded
May 12 07:40:02 caught kernel: klogd 1.4.1, log source = /proc/kmsg started.
May 12 07:40:02 caught kernel: Inspecting /boot/System.map-2.6.5-63077cl
May 12 07:40:02 caught syslog: klogd startup succeeded
May 12 07:40:02 caught kernel: Loaded 29534 symbols from /boot/System.map-2.6.5-63077cl.
May 12 07:40:02 caught kernel: Symbols match kernel version 2.6.5.
May 12 07:40:02 caught kernel: No module symbols loaded - kernel modules not enabled.
May 12 07:40:02 caught kernel: Linux version 2.6.5-63077cl (
[email protected]) (gcc version 3.3.3 (release)) #1 Thu Jun 17 20:05:07 BRT 2004
May 12 07:40:02 caught kernel: BIOS-provided physical RAM map:
May 12 07:40:02 caught kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
May 12 07:40:02 caught kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
May 12 07:40:02 caught kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
May 12 07:40:02 caught kernel: BIOS-e820: 0000000000100000 - 000000003fffc000 (usable)
May 12 07:40:02 caught kernel: BIOS-e820: 000000003fffc000 - 000000003ffff000 (ACPI data)
May 12 07:40:02 caught kernel: BIOS-e820: 000000003ffff000 - 0000000040000000 (ACPI NVS)
May 12 07:40:02 caught kernel: BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
May 12 07:40:02 caught kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
May 12 07:40:02 caught kernel: BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
May 12 07:40:02 caught kernel: Warning only 896MB will be used.
May 12 07:40:02 caught kernel: Use a HIGHMEM enabled kernel.
May 12 07:40:02 caught kernel: 896MB LOWMEM available.
May 12 07:40:02 caught kernel: On node 0 totalpages: 229376
May 12 07:40:02 caught kernel: DMA zone: 4096 pages, LIFO batch:1
May 12 07:40:02 caught kernel: Normal zone: 225280 pages, LIFO batch:16
May 12 07:40:02 caught kernel: HighMem zone: 0 pages, LIFO batch:1
May 12 07:40:02 caught kernel: DMI 2.3 present.
May 12 07:40:02 caught kernel: ACPI: RSDP (v000 ASUS ) @ 0x000f5710
May 12 07:40:02 caught kernel: ACPI: RSDT (v001 ASUS P4S800 0x42302e31 MSFT 0x31313031) @ 0x3fffc000
May 12 07:40:02 caught kernel: ACPI: FADT (v001 ASUS P4S800 0x42302e31 MSFT 0x31313031) @ 0x3fffc0c0
May 12 07:40:02 caught kernel: ACPI: BOOT (v001 ASUS P4S800 0x42302e31 MSFT 0x31313031) @ 0x3fffc030
May 12 07:40:02 caught kernel: ACPI: MADT (v001 ASUS P4S800 0x42302e31 MSFT 0x31313031) @ 0x3fffc058
May 12 07:40:02 caught kernel: ACPI: DSDT (v001 ASUS P4S800 0x00001000 MSFT 0x0100000b) @ 0x00000000
May 12 07:40:02 caught kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
May 12 07:40:02 caught kernel: Processor #0 15:3 APIC version 20
May 12 07:40:02 caught kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
May 12 07:40:02 caught kernel: Processor #1 15:3 APIC version 20
May 12 07:40:02 caught kernel: WARNING: NR_CPUS limit of 1 reached. Processor ignored.
May 12 07:40:02 caught kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
May 12 07:40:02 caught kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
May 12 07:40:02 caught kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] global_irq_base[0x0])
May 12 07:40:02 caught kernel: IOAPIC[0]: Assigned apic_id 2
May 12 07:40:02 caught kernel: IOAPIC[0]: apic_id 2, version 128, address 0xfec00000, GSI 0-23
May 12 07:40:02 caught kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl edge)
May 12 07:40:02 caught kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 20 low level)
May 12 07:40:02 caught kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
May 12 07:40:02 caught kernel: Using ACPI (MADT) for SMP configuration information
May 12 07:40:02 caught kernel: Built 1 zonelists
May 12 07:40:02 caught kernel: Kernel command line: root=/dev/hda1 vga=0x317 splash=silent 5
May 12 07:40:02 caught random: Iniciando gerador de números aleatórios: succeeded
May 12 07:40:02 caught kernel: bootsplash: silent mode.
May 12 07:40:02 caught kernel: Initializing CPU#0
May 12 07:40:02 caught kernel: PID hash table entries: 4096 (order 12: 32768 bytes)
May 12 07:40:02 caught kernel: Detected 3000.173 MHz processor.
May 12 07:40:02 caught kernel: Using tsc for high-res timesource
May 12 07:40:02 caught kernel: Console: colour dummy device 80x25
May 12 07:40:02 caught kernel: Memory: 903988k/917504k available (1768k kernel code, 12756k reserved, 876k data, 312k init, 0k highmem)
May 12 07:40:02 caught kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
May 12 07:40:02 caught kernel: Calibrating delay loop... 5931.00 BogoMIPS
May 12 07:40:02 caught kernel: Security Scaffold v1.0.0 initialized
May 12 07:40:02 caught kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
May 12 07:40:02 caught kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
May 12 07:40:02 caught kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
May 12 07:40:02 caught kernel: checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
May 12 07:40:02 caught kernel: Freeing initrd memory: 435k freed
May 12 07:40:02 caught kernel: monitor/mwait feature present.
May 12 07:40:02 caught kernel: using mwait in idle threads.
May 12 07:40:02 caught kernel: CPU: Trace cache: 12K uops
May 12 07:40:02 caught kernel: CPU: L2 cache: 1024K
May 12 07:40:02 caught kernel: Intel machine check architecture supported.
May 12 07:40:02 caught kernel: Intel machine check reporting enabled on CPU#0.
May 12 07:40:02 caught kernel: CPU#0: Intel P4/Xeon Extended MCE MSRs (12) available
May 12 07:40:02 caught kernel: CPU#0: Thermal monitoring enabled
May 12 07:40:02 caught kernel: CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz stepping 03
May 12 07:40:02 caught kernel: Enabling fast FPU save and restore... done.
May 12 07:40:02 caught kernel: Enabling unmasked SIMD FPU exception support... done.
May 12 07:40:02 caught kernel: Checking 'hlt' instruction... OK.
May 12 07:40:02 caught kernel: POSIX conformance testing by UNIFIX
May 12 07:40:02 caught kernel: enabled ExtINT on CPU#0
May 12 07:40:02 caught kernel: ESR value before enabling vector: 00000000
May 12 07:40:02 caught kernel: ESR value after enabling vector: 00000000
May 12 07:40:02 caught kernel: ENABLING IO-APIC IRQs
May 12 07:40:02 caught kernel: ..TIMER: vector=0x31 pin1=2 pin2=-1
May 12 07:40:02 caught kernel: Using local APIC timer interrupts.
May 12 07:40:02 caught kernel: calibrating APIC timer ...
May 12 07:40:02 caught kernel: ..... CPU clock speed is 2999.0583 MHz.
May 12 07:40:02 caught kernel: ..... host bus clock speed is 199.0972 MHz.
May 12 07:40:02 caught kernel: NET: Registered protocol family 16
May 12 07:40:02 caught kernel: EISA bus registered
May 12 07:40:02 caught kernel: PCI: PCI BIOS revision 2.10 entry at 0xf10c0, last bus=1
May 12 07:40:02 caught kernel: PCI: Using configuration type 1
May 12 07:40:02 caught kernel: mtrr: v2.0 (20020519)
May 12 07:40:02 caught kernel: ACPI: Subsystem revision 20040326
May 12 07:40:02 caught kernel: ACPI: Interpreter enabled
May 12 07:40:02 caught kernel: ACPI: Using IOAPIC for interrupt routing
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15)
May 12 07:40:02 caught kernel: ACPI: PCI Root Bridge [PCI0] (00:00)
May 12 07:40:02 caught kernel: PCI: Probing PCI hardware (bus 00)
May 12 07:40:02 caught kernel: Enabling SiS 96x SMBus.
May 12 07:40:02 caught kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
May 12 07:40:02 caught kernel: drivers/usb/core/usb.c: registered new driver usbfs
May 12 07:40:02 caught kernel: drivers/usb/core/usb.c: registered new driver hub
May 12 07:40:02 caught kernel: testing the IO APIC.......................
May 12 07:40:02 caught kernel: .................................... done.
May 12 07:40:02 caught kernel: PCI: Using ACPI for IRQ routing
May 12 07:40:02 caught kernel: PCI: if you experience problems, try using option 'pci=noacpi' or even 'acpi=off'
May 12 07:40:02 caught kernel: vesafb: framebuffer at 0xfc000000, mapped to 0xf8809000, size 4096k
May 12 07:40:02 caught kernel: vesafb: mode is 1024x768x16, linelength=2048, pages=0
May 12 07:40:02 caught kernel: vesafb: protected mode interface info at c000:0336
May 12 07:40:02 caught kernel: vesafb: scrolling: redraw
May 12 07:40:02 caught kernel: vesafb: directcolor: size=0:5:6:5, shift=0:11:5:0
May 12 07:40:02 caught kernel: fb0: VESA VGA frame buffer device
May 12 07:40:02 caught kernel: Simple Boot Flag at 0x3a set to 0x1
May 12 07:40:02 caught kernel: Machine check exception polling timer started.
May 12 07:40:02 caught kernel: Total HugeTLB memory allocated, 0
May 12 07:40:02 caught kernel: ikconfig 0.7 with /proc/config*
May 12 07:40:02 caught kernel: VFS: Disk quotas dquot_6.5.1
May 12 07:40:02 caught kernel: Initializing Cryptographic API
May 12 07:40:02 caught kernel: isapnp: Scanning for PnP cards...
May 12 07:40:02 caught kernel: isapnp: No Plug & Play device found
May 12 07:40:02 caught kernel: bootsplash 3.1.4-2004/02/19: looking for picture.... silentjpeg size 23674 bytes, found (1024x768, 18444 bytes, v3).
May 12 07:40:02 caught kernel: Console: switching to colour frame buffer device 128x38
May 12 07:40:02 caught kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
May 12 07:40:02 caught kernel: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
May 12 07:40:02 caught kernel: Using anticipatory io scheduler
May 12 07:40:02 caught kernel: Floppy drive(s): fd0 is 1.44M
May 12 07:40:02 caught kernel: FDC 0 is a post-1991 82077
May 12 07:40:02 caught kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
May 12 07:40:02 caught kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
May 12 07:40:02 caught kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
May 12 07:40:02 caught kernel: SIS5513: IDE controller at PCI slot 0000:00:02.5
May 12 07:40:02 caught kernel: SIS5513: chipset revision 0
May 12 07:40:02 caught kernel: SIS5513: not 100%% native mode: will probe irqs later
May 12 07:40:02 caught kernel: SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
May 12 07:40:02 caught kernel: ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hda
![Big Grin](images/smilies/biggrin.png)
MA, hdb
![Stick Out Tongue](images/smilies/tongue.png)
io
May 12 07:40:02 caught kernel: ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdc
MA, hdd
MA
May 12 07:40:02 caught kernel: hda: Maxtor 6Y120L0, ATA DISK drive
May 12 07:40:02 caught kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
May 12 07:40:02 caught kernel: hdc: HL-DT-ST GCE-8526B, ATAPI CD/DVD-ROM drive
May 12 07:40:02 caught kernel: hdd: ATAPI-CD ROM-DRIVE-56MAX, ATAPI CD/DVD-ROM drive
May 12 07:40:02 caught kernel: ide1 at 0x170-0x177,0x376 on irq 15
May 12 07:40:02 caught kernel: hda: max request size: 128KiB
May 12 07:40:02 caught kernel: hda: 240121728 sectors (122942 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(133)
May 12 07:40:02 caught kernel: hda: hda1 hda2
May 12 07:40:02 caught kernel: ohci_hcd 0000:00:03.0: Silicon Integrated Systems [SiS] USB 1.0 Controller
May 12 07:40:02 caught kernel: ohci_hcd 0000:00:03.0: irq 169, pci mem f8c17000
May 12 07:40:02 caught kernel: ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
May 12 07:40:02 caught kernel: hub 1-0:1.0: USB hub found
May 12 07:40:02 caught kernel: hub 1-0:1.0: 3 ports detected
May 12 07:40:02 caught kernel: ohci_hcd 0000:00:03.1: Silicon Integrated Systems [SiS] USB 1.0 Controller (#2)
May 12 07:40:02 caught kernel: ohci_hcd 0000:00:03.1: irq 209, pci mem f8c19000
May 12 07:40:02 caught kernel: ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
May 12 07:40:02 caught kernel: hub 2-0:1.0: USB hub found
May 12 07:40:02 caught kernel: hub 2-0:1.0: 3 ports detected
May 12 07:40:02 caught kernel: USB Universal Host Controller Interface driver v2.2
May 12 07:40:02 caught kernel: drivers/usb/core/usb.c: registered new driver hiddev
May 12 07:40:02 caught kernel: drivers/usb/input/hid-core.c: v2.0:USB HID core driver
May 12 07:40:02 caught kernel: mice: PS/2 mouse device common for all mice
May 12 07:40:02 caught kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
May 12 07:40:02 caught kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
May 12 07:40:02 caught kernel: input: AT Translated Set 2 keyboard on isa0060/serio0
May 12 07:40:02 caught kernel: md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
May 12 07:40:02 caught kernel: EISA: Probing bus 0 at eisa0
May 12 07:40:02 caught kernel: EISA: Detected 0 cards.
May 12 07:40:02 caught kernel: NET: Registered protocol family 2
May 12 07:40:02 caught kernel: IP: routing cache hash table of 8192 buckets, 64Kbytes
May 12 07:40:02 caught kernel: TCP: Hash tables configured (established 262144 bind 65536)
May 12 07:40:02 caught kernel: NET: Registered protocol family 17
May 12 07:40:02 caught kernel: NET: Registered protocol family 8
May 12 07:40:02 caught kernel: NET: Registered protocol family 20
May 12 07:40:02 caught kernel: ACPI: (supports S0 S1 S4 S5)
May 12 07:40:02 caught kernel: md: Autodetecting RAID arrays.
May 12 07:40:02 caught kernel: md: autorun ...
May 12 07:40:02 caught kernel: md: ... autorun DONE.
May 12 07:40:02 caught kernel: RAMDISK: Compressed image found at block 0
May 12 07:40:02 caught kernel: VFS: Mounted root (minix filesystem).
May 12 07:40:02 caught kernel: found reiserfs format "3.6" with standard journal
May 12 07:40:02 caught kernel: reiserfs: using ordered data mode
May 12 07:40:02 caught kernel: Reiserfs journal params: device hda1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
May 12 07:40:02 caught kernel: reiserfs: checking transaction log (hda1) for (hda1)
May 12 07:40:02 caught kernel: Using r5 hash to sort names
May 12 07:40:02 caught kernel: Freeing unused kernel memory: 312k freed
May 12 07:40:02 caught kernel: Real Time Clock Driver v1.12
May 12 07:40:02 caught kernel: input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
May 12 07:40:02 caught kernel: ts: Compaq touchscreen protocol output
May 12 07:40:02 caught kernel: input: PC Speaker
May 12 07:40:02 caught kernel: ALSA sound/pci/ac97/ac97_codec.c:1835: AC'97 0 analog subsections not ready
May 12 07:40:02 caught kernel: intel8x0_measure_ac97_clock: measured 49405 usecs
May 12 07:40:02 caught kernel: intel8x0: clocking to 48000
May 12 07:40:02 caught kernel: kjournald starting. Commit interval 5 seconds
May 12 07:40:02 caught kernel: EXT3 FS on hda2, internal journal
May 12 07:40:02 caught kernel: EXT3-fs: mounted filesystem with ordered data mode.
May 12 07:40:02 caught kernel: Supermount version 2.0.4 for kernel 2.6
May 12 07:40:02 caught kernel: Linux agpgart interface v0.100 (c) Dave Jones
May 12 07:40:02 caught kernel: agpgart: Detected SiS 648 chipset
May 12 07:40:02 caught kernel: agpgart: Maximum main memory to use for agp memory: 816M
May 12 07:40:02 caught kernel: agpgart: AGP aperture is 64M @ 0xf4000000
May 12 07:40:02 caught kernel: ehci_hcd 0000:00:03.3: Silicon Integrated Systems [SiS] USB 2.0 Controller
May 12 07:40:02 caught kernel: ehci_hcd 0000:00:03.3: irq 225, pci mem f8d78000
May 12 07:40:02 caught kernel: ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 3
May 12 07:40:02 caught kernel: PCI: cache line size of 128 is not supported by device 0000:00:03.3
May 12 07:40:02 caught kernel: ehci_hcd 0000:00:03.3: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29
May 12 07:40:02 caught kernel: hub 3-0:1.0: USB hub found
May 12 07:40:02 caught kernel: hub 3-0:1.0: 6 ports detected
May 12 07:40:02 caught kernel: Linux Kernel Card Services
May 12 07:40:02 caught kernel: options: [pci] [cardbus] [pm]
May 12 07:40:02 caught kernel: Intel ISA PCIC probe: not found.
May 12 07:40:02 caught kernel: Linux Tulip driver version 1.1.13-NAPI (May 11, 2002)
May 12 07:40:02 caught kernel: eth0: ADMtek Comet rev 17 at 0xf8dab000, 00:50:BF:AA:89:A0, IRQ 185.
May 12 07:40:03 caught netfs: Montando outros sistemas de arquivos: succeeded
May 12 07:40:03 caught atd: atd startup succeeded
May 12 07:40:03 caught crond: crond startup succeeded
May 12 07:40:02 caught sysctl: net.ipv4.ip_forward = 0
May 12 07:40:02 caught sysctl: net.ipv4.conf.all.rp_filter = 1
May 12 07:40:02 caught sysctl: net.ipv4.conf.default.rp_filter = 1
May 12 07:40:02 caught sysctl: kernel.sysrq = 1
May 12 07:40:02 caught sysctl: net.ipv4.conf.all.log_martians = 1
May 12 07:40:02 caught sysctl: net.ipv4.ip_dynaddr = 0
May 12 07:40:02 caught sysctl: net.ipv4.icmp_echo_ignore_broadcasts = 1
May 12 07:40:02 caught sysctl: net.ipv4.conf.all.accept_source_route = 0
May 12 07:40:02 caught sysctl: net.ipv4.icmp_echo_ignore_all = 0
May 12 07:40:02 caught sysctl: net.ipv4.icmp_ratemask = 6169
May 12 07:40:02 caught sysctl: net.ipv4.icmp_ratelimit = 100
May 12 07:40:02 caught sysctl: net.ipv4.tcp_syncookies = 1
May 12 07:40:02 caught sysctl: net.ipv4.conf.all.accept_redirects = 0
May 12 07:40:02 caught network: Configurando parâmetros de rede: succeeded
May 12 07:40:02 caught network: Levantando interface lo: succeeded
May 12 07:40:02 caught network: Bringing up interface eth0: succeeded
May 12 07:40:02 caught portmap: portmap startup succeeded
May 12 07:40:04 caught kernel: parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
May 12 07:40:04 caught kernel: parport0: irq 7 detected
May 12 07:40:04 caught kernel: lp0: using parport0 (polling).
May 12 07:40:04 caught kernel: lp0: console ready
May 12 07:40:04 caught cups: cupsd startup succeeded
May 12 07:40:04 caught gpm[2068]: *** info [startup.c(150)]:
May 12 07:40:04 caught gpm[2068]: Started gpm successfully. Entered daemon mode.
May 12 07:40:05 caught gpm: gpm startup succeeded
May 12 07:40:05 caught anacron[2123]: Anacron 2.3 started on 2005-05-12
May 12 07:40:05 caught anacron: anacron startup succeeded
May 12 07:40:05 caught anacron[2123]: Will run job `cron.daily' in 5 min.
May 12 07:40:05 caught anacron[2123]: Will run job `cron.weekly' in 10 min.
May 12 07:40:05 caught anacron[2123]: Will run job `cron.monthly' in 15 min.
May 12 07:40:05 caught anacron[2123]: Jobs will be executed sequentially
May 12 07:40:05 caught kernel: bootsplash: status on console 0 changed to on
May 12 07:40:05 caught kernel: bootsplash: freeing silent jpeg
May 12 07:40:05 caught kernel: apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
May 12 07:40:05 caught kernel: apm: overridden by ACPI.
May 12 07:40:06 caught modprobe: FATAL: Error inserting apm (/lib/modules/2.6.5-63077cl/kernel/arch/i386/kernel/apm.ko): No such device
May 12 07:40:06 caught kernel: atkbd.c: Unknown key released (translated set 2, code 0x7a on isa0060/serio0).
May 12 07:40:06 caught kernel: atkbd.c: This is an XFree86 bug. It shouldn't access hardware directly.
May 12 07:40:51 caught kde(pam_unix)[2174]: session opened for user sysop by (uid=0)
May 12 07:41:06 caught kernel: hdc: ATAPI 52X CD-ROM CD-R/RW CD-MRW drive, 2048kB Cache, UDMA(33)
May 12 07:41:06 caught kernel: Uniform CD-ROM driver Revision: 3.20
May 12 07:41:06 caught kernel: hdd: ATAPI 50X CD-ROM drive, 128kB Cache, UDMA(33)
May 12 07:42:21 caught kernel: usb 2-1: new full speed USB device using address 2
May 12 07:43:51 caught kernel: usb 2-1: USB disconnect, address 2
May 12 07:45:05 caught anacron[2123]: Job `cron.daily' started
May 12 07:45:05 caught anacron[2349]: Updated timestamp for job `cron.daily' to 2005-05-12
May 12 07:45:07 caught kernel: end_request: I/O error, dev fd0, sector 0
May 12 07:45:07 caught last message repeated 2 times
May 12 07:45:22 caught anacron[2123]: Job `cron.daily' terminated
May 12 07:50:05 caught anacron[2123]: Job `cron.weekly' started
May 12 07:50:05 caught anacron[2413]: Updated timestamp for job `cron.weekly' to 2005-05-12
May 12 07:51:02 caught anacron[2123]: Job `cron.weekly' terminated
May 12 07:55:05 caught anacron[2123]: Job `cron.monthly' started
May 12 07:55:05 caught anacron[2123]: Job `cron.monthly' terminated
May 12 07:55:05 caught anacron[2123]: Normal exit (3 jobs run)
May 12 07:55:05 caught anacron[8394]: Updated timestamp for job `cron.monthly' to 2005-05-12
May 12 08:23:57 caught gconfd (sysop-8433): iniciando (versão 2.6.1), pid 8433 usuário 'sysop'
May 12 08:23:57 caught gconfd (sysop-8433): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 08:23:57 caught gconfd (sysop-8433): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 08:23:57 caught gconfd (sysop-8433): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 08:28:27 caught gconfd (sysop-8433): O servidor GConf não está sendo usado, desligando.
May 12 08:28:27 caught gconfd (sysop-8433): Terminando
May 12 08:32:34 caught su(pam_unix)[8509]: session opened for user root by (uid=500)
May 12 08:32:34 caught su(pam_unix)[8509]: session closed for user root
May 12 08:32:34 caught su(pam_unix)[8514]: session opened for user root by (uid=500)
May 12 08:32:34 caught kernel: Capability LSM initialized
May 12 08:32:34 caught webmin: startup succeeded
May 12 08:32:34 caught su(pam_unix)[8514]: session closed for user root
May 12 08:33:39 caught network: Desligando interface eth0: succeeded
May 12 08:33:39 caught sysctl: net.ipv4.ip_forward = 0
May 12 08:33:39 caught sysctl: net.ipv4.conf.all.rp_filter = 1
May 12 08:33:39 caught sysctl: net.ipv4.conf.default.rp_filter = 1
May 12 08:33:39 caught sysctl: kernel.sysrq = 1
May 12 08:33:39 caught sysctl: net.ipv4.conf.all.log_martians = 1
May 12 08:33:39 caught sysctl: net.ipv4.ip_dynaddr = 0
May 12 08:33:39 caught sysctl: net.ipv4.icmp_echo_ignore_broadcasts = 1
May 12 08:33:39 caught sysctl: net.ipv4.conf.all.accept_source_route = 0
May 12 08:33:39 caught sysctl: net.ipv4.icmp_echo_ignore_all = 0
May 12 08:33:39 caught sysctl: net.ipv4.icmp_ratemask = 6169
May 12 08:33:39 caught sysctl: net.ipv4.icmp_ratelimit = 100
May 12 08:33:39 caught sysctl: net.ipv4.tcp_syncookies = 1
May 12 08:33:39 caught sysctl: net.ipv4.conf.all.accept_redirects = 0
May 12 08:33:39 caught network: Configurando parâmetros de rede: succeeded
May 12 08:33:39 caught network: Levantando interface lo: succeeded
May 12 08:33:39 caught network: Bringing up interface eth0: succeeded
May 12 08:33:43 caught network: Desligando interface eth0: succeeded
May 12 08:33:43 caught sysctl: net.ipv4.ip_forward = 0
May 12 08:33:43 caught sysctl: net.ipv4.conf.all.rp_filter = 1
May 12 08:33:43 caught sysctl: net.ipv4.conf.default.rp_filter = 1
May 12 08:33:43 caught sysctl: kernel.sysrq = 1
May 12 08:33:43 caught sysctl: net.ipv4.conf.all.log_martians = 1
May 12 08:33:43 caught sysctl: net.ipv4.ip_dynaddr = 0
May 12 08:33:43 caught sysctl: net.ipv4.icmp_echo_ignore_broadcasts = 1
May 12 08:33:43 caught sysctl: net.ipv4.conf.all.accept_source_route = 0
May 12 08:33:43 caught sysctl: net.ipv4.icmp_echo_ignore_all = 0
May 12 08:33:43 caught sysctl: net.ipv4.icmp_ratemask = 6169
May 12 08:33:43 caught sysctl: net.ipv4.icmp_ratelimit = 100
May 12 08:33:43 caught sysctl: net.ipv4.tcp_syncookies = 1
May 12 08:33:43 caught sysctl: net.ipv4.conf.all.accept_redirects = 0
May 12 08:33:43 caught network: Configurando parâmetros de rede: succeeded
May 12 08:33:43 caught network: Levantando interface lo: succeeded
May 12 08:33:43 caught network: Bringing up interface eth0: succeeded
May 12 09:02:38 caught gconfd (sysop-9495): iniciando (versão 2.6.1), pid 9495 usuário 'sysop'
May 12 09:02:38 caught gconfd (sysop-9495): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 09:02:38 caught gconfd (sysop-9495): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 09:02:38 caught gconfd (sysop-9495): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 09:05:08 caught gconfd (sysop-9495): O servidor GConf não está sendo usado, desligando.
May 12 09:05:08 caught gconfd (sysop-9495): Terminando
May 12 09:19:04 caught su(pam_unix)[9560]: session opened for user root by sysop(uid=500)
May 12 09:23:17 caught cups: cupsd shutdown succeeded
May 12 09:23:18 caught cups: cupsd startup succeeded
May 12 09:23:31 caught gconfd (root-9776): iniciando (versão 2.6.1), pid 9776 usuário 'root'
May 12 09:23:31 caught gconfd (root-9776): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 09:23:31 caught gconfd (root-9776): Endereço "xml:readwrite:/root/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 09:23:31 caught gconfd (root-9776): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 09:23:34 caught gconfd (root-9776): Terminando
May 12 09:24:36 caught gconfd (sysop-9926): iniciando (versão 2.6.1), pid 9926 usuário 'sysop'
May 12 09:24:37 caught gconfd (sysop-9926): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 09:24:37 caught gconfd (sysop-9926): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 09:24:37 caught gconfd (sysop-9926): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 09:24:44 caught webmin: shutdown succeeded
May 12 09:24:45 caught webmin: startup succeeded
May 12 09:24:48 caught webmin: shutdown succeeded
May 12 09:24:48 caught webmin: startup succeeded
May 12 09:24:53 caught webmin: shutdown succeeded
May 12 09:24:54 caught webmin: startup succeeded
May 12 09:28:07 caught gconfd (sysop-9926): O servidor GConf não está sendo usado, desligando.
May 12 09:28:07 caught gconfd (sysop-9926): Terminando
May 12 09:32:01 caught kernel: Kernel logging (proc) stopped.
May 12 09:32:01 caught kernel: Kernel log daemon terminating.
May 12 09:32:02 caught syslog: klogd shutdown succeeded
May 12 09:32:02 caught exiting on signal 15
May 12 09:32:02 lablinux syslogd 1.4.1: restart.
May 12 09:32:02 lablinux syslog: syslogd startup succeeded
May 12 09:32:02 lablinux kernel: klogd 1.4.1, log source = /proc/kmsg started.
May 12 09:32:02 lablinux kernel: Inspecting /boot/System.map-2.6.5-63077cl
May 12 09:32:02 lablinux syslog: klogd startup succeeded
May 12 09:32:03 lablinux kernel: Loaded 29534 symbols from /boot/System.map-2.6.5-63077cl.
May 12 09:32:03 lablinux kernel: Symbols match kernel version 2.6.5.
May 12 09:32:03 lablinux kernel: No module symbols loaded - kernel modules not enabled.
May 12 09:32:02 lablinux syslog: syslogd shutdown succeeded
May 12 09:32:34 lablinux su(pam_unix)[9560]: session closed for user root
May 12 10:00:31 lablinux gconfd (sysop-10751): iniciando (versão 2.6.1), pid 10751 usuário 'sysop'
May 12 10:00:31 lablinux gconfd (sysop-10751): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 10:00:31 lablinux gconfd (sysop-10751): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 10:00:31 lablinux gconfd (sysop-10751): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 10:04:01 lablinux gconfd (sysop-10751): O servidor GConf não está sendo usado, desligando.
May 12 10:04:01 lablinux gconfd (sysop-10751): Terminando
May 12 10:05:08 lablinux gconfd (sysop-10876): iniciando (versão 2.6.1), pid 10876 usuário 'sysop'
May 12 10:05:08 lablinux gconfd (sysop-10876): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 10:05:08 lablinux gconfd (sysop-10876): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 10:05:08 lablinux gconfd (sysop-10876): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 10:05:38 lablinux gconfd (sysop-10876): O servidor GConf não está sendo usado, desligando.
May 12 10:05:38 lablinux gconfd (sysop-10876): Terminando
May 12 10:08:03 lablinux su(pam_unix)[10902]: session opened for user root by sysop(uid=500)
May 12 10:08:41 lablinux gconfd (sysop-10925): iniciando (versão 2.6.1), pid 10925 usuário 'sysop'
May 12 10:08:41 lablinux gconfd (sysop-10925): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 10:08:41 lablinux gconfd (sysop-10925): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 10:08:41 lablinux gconfd (sysop-10925): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 10:15:43 lablinux network: Desligando interface eth0: succeeded
May 12 10:15:43 lablinux sysctl: net.ipv4.ip_forward = 0
May 12 10:15:43 lablinux sysctl: net.ipv4.conf.all.rp_filter = 1
May 12 10:15:43 lablinux sysctl: net.ipv4.conf.default.rp_filter = 1
May 12 10:15:43 lablinux sysctl: kernel.sysrq = 1
May 12 10:15:43 lablinux sysctl: net.ipv4.conf.all.log_martians = 1
May 12 10:15:43 lablinux sysctl: net.ipv4.ip_dynaddr = 0
May 12 10:15:43 lablinux sysctl: net.ipv4.icmp_echo_ignore_broadcasts = 1
May 12 10:15:43 lablinux sysctl: net.ipv4.conf.all.accept_source_route = 0
May 12 10:15:43 lablinux sysctl: net.ipv4.icmp_echo_ignore_all = 0
May 12 10:15:43 lablinux sysctl: net.ipv4.icmp_ratemask = 6169
May 12 10:15:43 lablinux sysctl: net.ipv4.icmp_ratelimit = 100
May 12 10:15:43 lablinux sysctl: net.ipv4.tcp_syncookies = 1
May 12 10:15:43 lablinux sysctl: net.ipv4.conf.all.accept_redirects = 0
May 12 10:15:43 lablinux network: Configurando parâmetros de rede: succeeded
May 12 10:15:43 lablinux network: Levantando interface lo: succeeded
May 12 10:15:43 lablinux network: Bringing up interface eth0: succeeded
May 12 10:16:27 lablinux su(pam_unix)[10902]: session closed for user root
May 12 10:16:56 lablinux su(pam_unix)[11646]: session opened for user root by sysop(uid=500)
May 12 10:32:40 lablinux named[11753]: starting BIND 9.2.3 -u named -t /var/named
May 12 10:32:40 lablinux named[11753]: using 1 CPU
May 12 10:32:40 lablinux named[11753]: loading configuration from '/etc/named.conf'
May 12 10:32:40 lablinux named[11753]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
May 12 10:32:40 lablinux named[11753]: no IPv6 interfaces found
May 12 10:32:40 lablinux named[11753]: listening on IPv4 interface lo, 127.0.0.1#53
May 12 10:32:40 lablinux named[11753]: listening on IPv4 interface eth0, 192.168.0.254#53
May 12 10:32:40 lablinux named[11753]: command channel listening on 127.0.0.1#953
May 12 10:32:40 lablinux named[11753]: couldn't open pid file '/var/run/named/named.pid': Permission denied
May 12 10:32:40 lablinux named[11753]: exiting (due to early fatal error)
May 12 10:34:06 lablinux su(pam_unix)[11646]: session closed for user root
May 12 10:39:14 lablinux named[12005]: starting BIND 9.2.3 -u named -t /var/named
May 12 10:39:14 lablinux named[12005]: using 1 CPU
May 12 10:39:14 lablinux named[12005]: loading configuration from '/etc/named.conf'
May 12 10:39:14 lablinux named[12005]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
May 12 10:39:14 lablinux named[12005]: no IPv6 interfaces found
May 12 10:39:14 lablinux named[12005]: listening on IPv4 interface lo, 127.0.0.1#53
May 12 10:39:14 lablinux named[12005]: listening on IPv4 interface eth0, 192.168.0.254#53
May 12 10:39:14 lablinux named[12005]: command channel listening on 127.0.0.1#953
May 12 10:39:14 lablinux named[12005]: couldn't open pid file '/var/run/named/named.pid': Permission denied
May 12 10:39:14 lablinux named[12005]: exiting (due to early fatal error)
May 12 10:40:57 lablinux named[12605]: starting BIND 9.2.3 -u named -t /var/named
May 12 10:40:57 lablinux named[12605]: using 1 CPU
May 12 10:40:57 lablinux named[12605]: loading configuration from '/etc/named.conf'
May 12 10:40:57 lablinux named[12605]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
May 12 10:40:57 lablinux named[12605]: no IPv6 interfaces found
May 12 10:40:57 lablinux named[12605]: listening on IPv4 interface lo, 127.0.0.1#53
May 12 10:40:57 lablinux named[12605]: listening on IPv4 interface eth0, 192.168.0.254#53
May 12 10:40:57 lablinux named[12605]: command channel listening on 127.0.0.1#953
May 12 10:40:57 lablinux named[12605]: couldn't open pid file '/var/run/named/named.pid': Permission denied
May 12 10:40:57 lablinux named[12605]: exiting (due to early fatal error)
May 12 10:51:48 lablinux su(pam_unix)[12647]: session opened for user root by sysop(uid=500)
May 12 11:00:11 lablinux gconfd (sysop-10925): O servidor GConf não está sendo usado, desligando.
May 12 11:00:11 lablinux gconfd (sysop-10925): Terminando
May 12 11:00:13 lablinux su(pam_unix)[12647]: session closed for user root
May 12 11:39:51 lablinux gconfd (sysop-12731): iniciando (versão 2.6.1), pid 12731 usuário 'sysop'
May 12 11:39:52 lablinux gconfd (sysop-12731): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 11:39:52 lablinux gconfd (sysop-12731): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 11:39:52 lablinux gconfd (sysop-12731): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 11:43:56 lablinux su(pam_unix)[12745]: session opened for user root by sysop(uid=500)
May 12 11:44:26 lablinux named[12772]: starting BIND 9.2.3 -u named -t /var/named
May 12 11:44:26 lablinux named[12772]: using 1 CPU
May 12 11:44:26 lablinux named[12772]: loading configuration from '/etc/named.conf'
May 12 11:44:26 lablinux named[12772]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
May 12 11:44:26 lablinux named[12772]: no IPv6 interfaces found
May 12 11:44:26 lablinux named[12772]: listening on IPv4 interface lo, 127.0.0.1#53
May 12 11:44:26 lablinux named[12772]: listening on IPv4 interface eth0, 192.168.0.254#53
May 12 11:44:26 lablinux named[12772]: command channel listening on 127.0.0.1#953
May 12 11:44:26 lablinux named[12772]: couldn't open pid file '/var/run/named/named.pid': Permission denied
May 12 11:44:26 lablinux named[12772]: exiting (due to early fatal error)
May 12 11:45:27 lablinux named: named shutdown failed
May 12 11:45:27 lablinux named[12864]: starting BIND 9.2.3 -u named -t /var/named
May 12 11:45:27 lablinux named[12864]: using 1 CPU
May 12 11:45:27 lablinux named[12864]: loading configuration from '/etc/named.conf'
May 12 11:45:27 lablinux named[12864]: /etc/named.conf:15: option 'memstatistics-file' is not implemented
May 12 11:45:27 lablinux named[12864]: no IPv6 interfaces found
May 12 11:45:27 lablinux named[12864]: listening on IPv4 interface lo, 127.0.0.1#53
May 12 11:45:27 lablinux named[12864]: listening on IPv4 interface eth0, 192.168.0.254#53
May 12 11:45:27 lablinux named[12864]: command channel listening on 127.0.0.1#953
May 12 11:45:27 lablinux named[12864]: couldn't open pid file '/var/run/named/named.pid': Permission denied
May 12 11:45:27 lablinux named[12864]: exiting (due to early fatal error)
May 12 11:48:46 lablinux su(pam_unix)[12745]: session closed for user root
May 12 11:48:52 lablinux gconfd (sysop-12731): O servidor GConf não está sendo usado, desligando.
May 12 11:48:52 lablinux gconfd (sysop-12731): Terminando
May 12 11:53:50 lablinux gconfd (sysop-12966): iniciando (versão 2.6.1), pid 12966 usuário 'sysop'
May 12 11:53:50 lablinux gconfd (sysop-12966): Endereço "xml:readonly:/etc/gconf/gconf.xml.mandatory" resolvido para uma fonte de configuração somente leitura na posição 0
May 12 11:53:50 lablinux gconfd (sysop-12966): Endereço "xml:readwrite:/home/sysop/.gconf" resolvido para uma fonte de configuração com permissões de escrita na posição 1
May 12 11:53:50 lablinux gconfd (sysop-12966): Endereço "xml:readonly:/etc/gconf/gconf.xml.defaults" resolvido para uma fonte de configuração somente leitura na posição 2
May 12 11:55:43 lablinux su(pam_unix)[12975]: session opened for user root by sysop(uid=500)
May 12 12:01:08 lablinux su(pam_unix)[12990]: authentication failure; logname=sysop uid=500 euid=0 tty= ruser=sysop rhost= user=root
May 12 12:01:18 lablinux su(pam_unix)[12992]: session opened for user root by sysop(uid=500)
