- Netlogon Samba
Netlogon Samba
Apos configurar samba redondo ele funciona blz.. tudo acontece como deve
acontecer...
só que isto acontece apenas na primeira ves que eu me logo na segunda os
volumes mapeados pelo w2k(netlogon) não estão mais acessíveis.O servidor
fica incessivel, pede senha e mesmo assim não funciona...
alguem tem idéia do que pode estar acontecendo??
Segue abaixo meu smb.conf
[global]
null passwords = yes
workgroup = MEDITEC
log file = /var/log/samba/log.%m
max log size = 50
debug level = 1
security = user
password level = 8
username level = 8
encrypt passwords = no
smb passwd file = /etc/smbpasswd
unix password sync = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n
*passwd:*all*authentication*tokens*updated*successfully*
username map = /etc/smbusers
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
local master = yes
os level = 100
domain master = yes
preferred master = yes
domain controller = Server
domain logons = yes
logon script = %U.bat
logon path =
;name resolve order = wins lmhosts bcast
wins support = yes
; wins server = w.x.y.z
wins proxy = no
dns proxy = no
unix password sync = yes
netbios name = Server
map to guest = never
; preserve case = no
; short preserve case = no
; default case = lower
; case sensitive = no
logon drive = t:
#============================ Share Definitions
[homes]
comment = Home Directories
browseable = yes
writable = yes
available = yes
only user = no
# Un-comment the following and create the netlogon directory for Domain
Logons
[netlogon]
comment = Network Logon Service
path = /files/net
writable = no
browseable = no
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
guest ok = no
writable = no
printable = yes
[meditec]
comment = med
path = /files/med
writable = yes
browseable = yes
[tox]
comment = tox
path = /files/tox
writable = yes
browseable = yes
write list = @users
[rs]
comment = rs
path = /files/rs
writable = yes
browseable = yes
[lukra]
comment = lukra
path = /files/lukra
writable = yes
browseable = yes
force create mode = 777
[publico]
comment = pub
path = /files/pub
writable = yes
browseable = yes
sync always = yes
force directory mode = 777
create mask = 777
[catalogo]
comment = cat
path = /files/cat
public = yes
writable = yes
browseable = yes
create mask = 777
Netlogon Samba
Tenta pro um:
valid users = user1, user2, user3...
Netlogon Samba
Todos os processos estão rodando normalmente...
Consegui chegar a seguinte conclusão:
Quando deixo no samba o "login script = %U.bat" ele funciona na primeira vez e na segundao script nem é executado na estação...e todos os caminhos já mapeados não funcionam...desta forma não consigo nem acesso ao server (pede senha, e nehuma funciona , nem root).
Quando comento a linha (também comento tudo referente ao diretorio home do user) consigo acessar manualmente (mas só se eu desfazer os mapeamentos no w2k).
Ou seja, quando o mapeamento existe no w2k ele parece fechar a conexão entre server/estação.
è Estranho...
Segue abaixo o smb.conf mais recente...
[global]
workgroup = MEDITEC
server string = Samba Server
; hosts allow = 192.168.1. 192.168.2. 127.
printcap name = /etc/printcap
load printers = yes
printing = lprng
guest account = root
log file = /var/log/samba/log.%U
max log size = 50
debug level = 1
security = user
; password server = <NT-Server-Name>
password level = 8
username level = 8
passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
; include = /etc/smb.conf.%m
; interfaces = 192.168.12.2/24 192.168.13.2/24
; remote browse sync = 192.168.3.25 192.168.5.255
; remote announce = 192.168.1.255 192.168.2.44
local master = yes
os level = 99
domain master = yes
; domain controller = <NT-Domain-Controller-SMBName>
domain logons = yes
; logon script = %m.bat
logon path =
logon home =
wins support = yes
; wins proxy = yes
dns proxy = no
; unix password sync = yes
netbios name = SERVER
preserve case = no
case sensitive = no
admin users = root, osni
valid users = osni, teste, andrea, administrador, root
;logon drive = t:
remote browse sync = 192.168.0.255
remote announce = 192.168.0.255
create mask = 0777
time server = yes
domain admin group = root
#============================ Share Definitions ==============================
;[homes]
; comment = Home Directories
; browseable = yes
; writable = yes
; available = yes
; public = yes
[netlogon]
path = /files/netlogon
guest ok = yes
writable = yes
browseable = yes
[meditec]
comment = meditec
path = /files/med
public = yes
writable = yes
browseable = yes
[tox]
comment = tox
path = /files/tox
public = yes
writable = yes
browseable = yes
[rs]
comment = rs
path = /files/rs
public = yes
writable = yes
browseable = yes
[lukra]
comment = lukra
path = /files/lukra
public = yes
writable = yes
browseable = yes
[publico]
comment = publico
path = /files/pub
public = yes
writable = yes
browseable = yes
[catalog]
comment = catalogos
path = /files/cat
public = yes
writable = yes
browseable = yes
[IPC$]
path = /files/ipc
public = yes
writable = yes
browseable = no
[admin$]
path = /files/winnt
public = yes
writable = yes
browseable = no
[C$]
path = /files/c
public = yes
writable = yes
browseable = no
Netlogon Samba
Se vc tem 2k/XP na rede como fez para entrar no dominio?
Como esta o seu script de logon?
veja se isto aqui funciona:
@echo off
rem Logon script padrão para a rede.
net time /domain:SEUDOMINIO
if %OS%.==Windows_NT. goto WinNT
:Win95
net use M: \\NETBIOS_NAME_SEU_SERVER\public /yes
net use L: \\NETBIOS_NAME_SEU_SERVER\HOMES /yes
goto end
:WinNT
net use M: \\NETBIOS_NAME_SEU_SERVER\public /persistent:no
:end
Marcos Amorim
[ Esta mensagem foi editada por: marcosmamorim em 25-02-2003 10:16 ]
Netlogon Samba
tenta efetuar um logoff antes de logar novamente pode ser que para o samba ele ainda esteja logado, pois ele mantem a conexão ativa mesmo após o seu uso por um bom tempo
