Galera estou com uma baita problema no mysql ... instalei ele agora no mandrake 9 e esta dando alguns problemas..
$ mysql_install_db
WARNING: The host 'server' could not be looked up with resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MySQL version. The MySQL daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MySQL privileges !
Installing all prepared tables
060727 13:39:39 Warning: Asked for 196608 thread stack, but got 126976
/usr/sbin/mysqld: Can't read dir of '/root/tmp/' (Errcode: 13)
060727 13:39:39 /usr/sbin/mysqld: Shutdown Complete
Como faco para arrumar isso ?
Um abraco
