Na verdade já vi vários tópicos a respeito, mas mesmo assim não consigo nem pingar o switch frame-relay da telefonica a partir do meu roteador. Segue a minha configuração, se alguém puder me dizer onde errei, agradeço.
________________________________________________________________
Encapsulation Frame Relay
IP protocol active
Interface Numbered
Primary IP address 201.xxx.yyy.zz2 (IP_WAN_LOCAL)
Subnet mask 255.255.255.252
IP MTU 1500
IP Fragmentation bit DF - accept
NAT - Address Scope Global
ICMP Port inactive
Incoming Filter List None
Detailed Incoming IP Accounting Process inactive
Outgoing Filter List None
Detailed Outgoing IP Accounting Process inactive
Routing of Broadcast Messages inactive
Interface Transparent Bridge Inactive
Sync mode
External Clock Source
Don't invert clock phase for transmission
Interface V.35
Bandwidth 0
IP Traffic Control List None
Encapsulation Type RFC1490 - IETF
SNAP IP inactive
LMI type Q933a
Alternative DLCI routing disabled for this link
T391 in seconds 10
N391 6
N392 3
N393 4
FRF-12 - without fragmentation
Number of DLCI's 1
Frame Relay MAP
# DLCI Remote IP addr Local IP addr CIR Pred Ctrl
01 111 201.xxx.yyy.zz1 100 Dis None
(IP_WAN_REMOTO)
DLCI Traffic Control inactive
SNMP interface :
Interface UP/Down TRAP Disable
_________________________________________________________________________
IP Static Routes
Destination Subnet Mask Gateway/Interf Metric/Bkp/RIP OSPF/ExType
Default Gateway 201.xxx.yyy.zz1 1 no no no
(IP_WAN_REMOTO)
