- Erros no Conectiva 9...
Galera, ao examinar o .xsession-errors e encontrei isso:
<stdin>:100: warning: backslash-newline at end of file
kbuildsycoca running...
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/lib/libkdecore.so.4: undefined symbol: init_keyboard_layout
ERROR: kmix: Mixer não foi encontrado.
Verifique se a placa de som está instalada e o
driver de som está carregado.
10
20
25
37
50
62
75
80
85
90
mcop warning: user defined signal handler found for SIG_PIPE, overriding
WARNING: KDE detected X Error: BadDrawable (invalid Pixmap or Window parameter) \x09
Major opcode: \x0e
libpng warning: Ignoring gAMA chunk with gamma=0
libpng warning: Invalid cHRM white point
WARNING: KDE detected X Error: BadMatch (invalid parameter attributes) \x08
Major opcode: *
ASSERT: "!name.isEmpty()" in kinstance.cpp (56)
ASSERT: "i <= nodes" in /usr/lib/qt3/include/qvaluelist.h (372)
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/lib/libkdecore.so.4: undefined symbol: PKCS7_content_free
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/lib/libkdecore.so.4: undefined symbol: OpenSSL_add_all_algorithms
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/lib/libkdecore.so.4: undefined symbol: OpenSSL_add_all_algorithms_conf
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/lib/libkdecore.so.4: undefined symbol: OpenSSL_add_all_algorithms_noconf
kio (KMimeType): WARNING: KServiceType:<IMG SRC="images/forum/icons/icon_eek.gif">ffers : servicetype application/x-activex-handler not found
22:15:06: [WRN] Current Licq GMT offset (6) does not match system GMT offset (0).
Update general info on server to fix.
Major opcode: *
kio (KMimeType): WARNING: KServiceType:<IMG SRC="images/forum/icons/icon_eek.gif">ffers : servicetype audio/x-pn-realaudio-plugin not found
khtml (jscript): WARNING: Script threw exception: SyntaxError: Parse error at line 2
khtml (part): WARNING: KHTMLPart::scheduleRedirection: Redirection from http://www.pop.com.br/popalerta/mostra.php?url=http://www.pop.com.br" to http://www.pop.com.br" REJECTED!
kdecore (KAction): WARNING: KActionCollection::KActionCollection( QObject *parent, const char *name, KInstance *instance )
Uso o Conectiva 9 com os pacotes do SnapShot...
Dentre esses erros, o da placa de som eu não entendo, tenho uma SBlive e o módulo está carregado e funcionando, o que poderia ser esse erro do KMix ???
O restante vejo que são erros do KDE...
Alguma idéia de como resolver algum dos problemas acima ???
Valeu....
