root@proxy:~# tail /var/log/syslog
Oct 17 16:21:14 proxy squid[4058]: parseHttpRequest: Unsupported method 'recipientid=111&sessionid=9224^M '
Oct 17 16:21:14 proxy squid[4058]: clientReadRequest: FD 42 (10.0.56.2:1418) Invalid Request
Oct 17 16:21:16 proxy squid[4058]: parseHttpRequest: Unsupported method 'recipientid=115&sessionid=5039^M '
Oct 17 16:21:16 proxy squid[4058]: clientReadRequest: FD 53 (10.0.56.2:1419) Invalid Request
Oct 17 16:38:46 proxy -- MARK --
Oct 17 16:51:32 proxy squid[4058]: parseHttpRequest: Requestheader contains NULL characters
Oct 17 16:51:32 proxy squid[4058]: parseHttpRequest: Unsupported method '^C^Aû|'
Oct 17 16:51:32 proxy squid[4058]: clientReadRequest: FD 53 (10.0.32.2:2192) Invalid Request
Oct 17 16:57:58 proxy squid[4058]: httpReadReply: Excess data from "GET http://a29876.upd.maximumexperience.com/upd/check?version=5.23msn&localeId=1046&affid=70000019&guid=61af97a26c06913d&windowsVersion=2:5:1:2600:3:0&rversion=5.23msn&updatevalue=15&fxp=f4524edf25c3ad1b7c7294d485275f039bf095dd71f15c68c04f7d05a3fc94d457aeda0b"
Oct 17 17:17:01 proxy /USR/SBIN/CRON[6287]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
root@proxy:~# tail /var/log/dmesg
[ 31.051908] kjournald starting. Commit interval 5 seconds
[ 31.052059] EXT3 FS on sda7, internal journal
[ 31.052063] EXT3-fs: mounted filesystem with ordered data mode.
[ 31.074033] kjournald starting. Commit interval 5 seconds
[ 31.074178] EXT3 FS on sda8, internal journal
[ 31.074183] EXT3-fs: mounted filesystem with ordered data mode.
[ 31.092543] kjournald starting. Commit interval 5 seconds
[ 31.092682] EXT3 FS on sda9, internal journal
[ 31.092697] EXT3-fs: mounted filesystem with ordered data mode.
[ 31.823303] ip_tables: (C) 2000-2006 Netfilter Core Team
root@proxy:/var/log# cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda2
UUID=37aed644-a449-4b9d-9207-007c5431d659 / ext3 defaults,noatime,errors=remount-ro 0 1
# /dev/sda5
UUID=d25d30bd-7500-4e69-84d0-211b8e9f1802 /var/spool/squid/cache1 ext3 defaults,noatime 0 2
# /dev/sda6
UUID=5815544d-c019-4f34-83a8-cc45a5b1c350 /var/spool/squid/cache2 ext3 defaults,noatime 0 2
# /dev/sda7
UUID=6f2a2f6f-7ba9-4bcc-ac75-1dd3e181166d /var/spool/squid/cache3 ext3 defaults,noatime 0 2
# /dev/sda8
UUID=6b3277d0-629a-4d7c-af87-4e02e477bec0 /var/spool/squid/cache4 ext3 defaults,noatime 0 2
# /dev/sda9
UUID=5702641c-929a-4f1d-bb20-6e55d90c9311 /var/spool/squid/cache5 ext3 defaults,noatime 0 2
# /dev/sda1
UUID=52a4ef94-89c5-466c-92c8-93a2cfd1ed89 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
###antes as opitions eram relatime, sem defaults... dps de varias fuçadas no oracle.. deixei em defaults,noatime
###pois o squid tem seu timestamp, sem a necessidade de usar o timestamp do sistema..
gostaria da ajuda dos amigos, sobre esses erros,, do syslog,,
e no caso do dmesg,, essas options estao corratas? ou matenho em relatime?
aguardo a ajuda de vcs
vlw galera
Citação
