Postado originalmente por
Roots
Radio Card Default /ProgrammedMax Power Offset True Max Avg. Output Power
SR2 16 dBm 10 dB 26 dBm
SR9 16 dBm 12 dB 28 dBm
SR5 19 dBm 7 dB 26 dBm
XR2 18 dBm 10 dB 28 dBm
XR5 18 dBm 10 dB 28 dBm
Because of problems with TX power control in certain versions of the Atheros
MADWIFI Linux Driver, the SR / XR cards were purposely programmed with a
power "offset" which causes the driver to think it is transmitting at a lower power
level than it really is. The table below shows the maximum power levels
programmed into the cards versus the actual corresponding output power levels. It
is important to realize that what the driver reports will be significantly lower than the
TX power of the radio.
It is always a good idea to leave power levels at their default settings as this will
produce radio operation according to the SR / XR specifications. If there are any
questions concerning power offsets, please contact
[email protected] or give us
a call at 408-942-1153.
é isso aí galera...é só deixar em default...
Lucivanio Gama
