Postado originalmente por
LASERNET
Olá amigo, o meu squid.conf é esse veja por favor o que vc acha, inclusive o maximum_object_size_in_memory 64 KB
eu não consigo mudar para maximum_object_size_in_memory 128 KB, quando eu mudo faço backup e reinicio volta do mesmo jeoto que tava, já fiz isto atrves de editar qualquer arquivo no bfw e do winsscp. o que vc acha?
http_port 3128 transparent
icp_port 0
hierarchy_stoplist cgi-bin ?
acl video_cache dstdomain -i "/usr/local/squid/etc/cache.flt"
cache allow video_cache
cache deny QUERY
#cache_replacement_policy heap LRU
cache_replacement_policy heap LFUDA
memory_replacement_policy heap GDSF
cache_mem 156 MB
maximum_object_size 20000 KB
minimum_object_size 4 KB
cache_dir diskd /partition/squid/cache 5000 16 256 Q1=72 Q2=64
cache_access_log none
cache_store_log none
cache_effective_user nobody
cache_effective_group nogroup
pid_filename /var/run/squid.pid
half_closed_clients off
server_persistent_connections off
client_persistent_connections off
memory_pools off
buffered_logs on
pipeline_prefetch on
#cache_swap_low 70
#cache_swap_high 90
refresh_pattern -i ^http://.*\.(css|htm|html|ico|js|jsp|xml)$ 1440 80% 999999
refresh_pattern -i ^http://.*\.(bmp|gif|jpeg|jpg|png)$ 1440 80% 999999 ignore-reload
refresh_pattern -i ^http://.*\.(ace|adt|arj|asf|avi|bin|bz2|bzip|cab|dat|dll|doc|dot|exe|fla|flv|gz|iso|lha|log|lzh|mdb|mid|mov|mp3|mpeg|mpg|msi|mso|ogg|pps|ppt|rar|rm|rtf|shs|src|sys|swf|tgz|tif|ttf|wav|wma|wri|wmv|vpu|vpaa|vqf|vob|zip)$ 43200 100% 999999 ignore-reload
refresh_pattern . 0 20% 4320
acl all src 0.0.0.0/0.0.0.0
#acl to_localhost dst 127.0.0.1/32
acl SSL_ports port 443 563
acl Safe_ports port 80
acl Safe_ports port 21
acl Safe_ports port 443 563
acl Safe_ports port 70
acl Safe_ports port 210
acl Safe_ports port 8180
acl Safe_ports port 1025-65535
acl Safe_ports port 280
acl Safe_ports port 488
acl Safe_ports port 591
acl Safe_ports port 777
acl Safe_ports port 901
acl purge method PURGE
acl CONNECT method CONNECT
#Access deny to Squid ident. header
header_access Via deny all
header_access X-Forwarded-For deny all
header_access Proxy-Connection deny all
header_access Accept-Encoding deny all
zph_mode tos
zph_local 0x30
acl filterneg dstdom_regex "/usr/local/squid/etc/filter.flt"
acl downloads_blocked urlpath_regex -i \.scr$ \.bat$ \.pif$ \.cmd$\.rmvb$\.3gp.rar$\.avi$
acl internal_net src "/usr/local/squid/etc/ipaccess.yes"
http_access deny manager
http_access deny !Safe_ports
http_access allow PURGE localhost
http_access deny purge
http_access deny filterneg
http_reply_access deny downloads_blocked
http_access allow internal_net
http_access deny all
#http_reply_access allow all
#icp_access allow all
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
visible_hostname brazilfw
coredump_dir /partition/squid/cache
error_directory /usr/local/squid/share/errors/Portuguese
