Olá pessoal, estou enfrentando uma dificuldade para re-configurar minha RB750g. Acontece que o balance não está sendo reconhecido ou algo do tipo, sendo que a configuração está toda certa, pelo que creio. ME AJUDEM PLSS
Script balance:
/ ip firewall mangle
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=bridge
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=bridge
add chain=prerouting in-interface=wan1 connection-mark=no-mark action=mark-connection \
new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection \
new-connection-mark=ISP2_conn
add chain=prerouting in-interface=bridge connection-mark=no-mark dst-address-type=!local \
per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
add chain=prerouting connection-mark=ISP1_conn in-interface=bridge action=mark-routing \
new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=bridge action=mark-routing \
new-routing-mark=to_ISP2
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
NAT, ROTA E DNS está tudo ok. Porém só funciona um ou outro, nunca os dois simultaneamente.
Se estiver faltando algo é só comentar gente, que esclareco. Obrigado.
