- firewall teste
firewall teste
boa tarde
estou montando um firewall e gostaria de testar para saber o quanto estou segura alguem poderia me ajudar ?
firewall teste
heheheh passa o seu ip ae!!!
firewall teste
firewall teste
amigo nao esta respondendo nao!!!!!
Acho que vc me engano ou postou o ip errado ou a maquina esta desligado!!! 8)
firewall teste
o ip esse mesmo
e esta online
firewall teste
(no tcp responses received -- assuming all ports filtered)
All 1660 scanned ports on 200.207.152.27 are: filtered
1660 portas abertas.....
firewall teste
Adding open port 1481/tcp
Adding open port 503/tcp
Adding open port 1398/tcp
Adding open port 346/tcp
Adding open port 350/tcp
Adding open port 730/tcp
Adding open port 2007/tcp
Adding open port 1446/tcp
Adding open port 26/tcp
Adding open port 209/tcp
Adding open port 56/tcp
Adding open port 471/tcp
Adding open port 816/tcp
Adding open port 1526/tcp
Adding open port 580/tcp
Adding open port 389/tcp
Adding open port 384/tcp
Adding open port 13782/tcp
Adding open port 1546/tcp
Adding open port 467/tcp
Adding open port 94/tcp
Adding open port 377/tcp
Adding open port 1059/tcp
Adding open port 7326/tcp
Adding open port 46/tcp
Adding open port 1367/tcp
Adding open port 1409/tcp
Adding open port 721/tcp
Adding open port 404/tcp
Adding open port 264/tcp
Adding open port 2903/tcp
Adding open port 697/tcp
Adding open port 7070/tcp
Adding open port 982/tcp
Adding open port 1984/tcp
Adding open port 1214/tcp
Adding open port 1479/tcp
Adding open port 632/tcp
Adding open port 913/tcp
Adding open port 391/tcp
Adding open port 711/tcp
Adding open port 9/tcp
Adding open port 667/tcp
Adding open port 767/tcp
Adding open port 4144/tcp
Adding open port 3292/tcp
Adding open port 782/tcp
Adding open port 775/tcp
Adding open port 2017/tcp
Adding open port 232/tcp
Adding open port 322/tcp
Adding open port 885/tcp
Adding open port 2006/tcp
Adding open port 2053/tcp
Adding open port 879/tcp
Adding open port 67/tcp
Adding open port 32776/tcp
Adding open port 875/tcp
Adding open port 371/tcp
Adding open port 738/tcp
Adding open port 3052/tcp
Adding open port 387/tcpAdding open port 119/tcp
Adding open port 3/tcp
Adding open port 497/tcp
Adding open port 2026/tcp
Adding open port 4559/tcp
Adding open port 1002/tcp
Adding open port 882/tcp
Adding open port 2564/tcp
Adding open port 570/tcp
Adding open port 1670/tcp
Adding open port 302/tcp
Adding open port 426/tcp
Adding open port 419/tcp
Adding open port 339/tcp
Adding open port 2064/tcp
Adding open port 1524/tcp
Adding open port 1016/tcp
Adding open port 170/tcp
Adding open port 871/tcp
Adding open port 3372/tcp
Adding open port 559/tcp
Adding open port 33/tcp
Adding open port 1442/tcp
Adding open port 535/tcp
Adding open port 105/tcp
Adding open port 24/tcp
Adding open port 1412/tcp
Adding open port 205/tcp
Adding open port 18181/tcp
Adding open port 7003/tcp
Adding open port 177/tcp
isso foi oq coube no buffer do meu terminal!!!
filtra direito issa mane!
firewall teste
Sinceramente? Eu acho que você está rodando um honeypot. =)
firewall teste
aii ai.... se ta "filtered" o firewall está barrando, e o portscan não sabe se a porta está realmente aberta ou não.... isto é um falso-positivo... até parece que iria ter 1600 portas aberta lá 8O
firewall teste
hahahahhahahahah ow dexa eu zua cara meu!!!!! vcs estraga a brincadara
firewall teste
firewall teste
firewall teste
scaneei da porta 20 ate a 150 apenas....
Starting nmap 3.45 ( http://www.insecure.org/nmap/ ) at 2004-11-05 14:59 BRST
Interesting ports on 200-207-152-27.speedyterra.com.br (200.207.152.27):
(The 126 ports scanned but not shown below are in state: filtered)
PORT STATE SERVICE VERSION
21/tcp open ftp Microsoft ftpd 5.0
25/tcp open smtp Postfix smtpd
53/tcp closed domain
80/tcp open http Microsoft IIS webserver 5.0
110/tcp open pop3 UW Imap pop3 server 2003.83rh
firewall teste
eh mas ele ta vuneravel mesmo assim... ele nao ta filtrando as flag tcp.... consegui faze um FIN scan nele
firewall teste
Ai galera, cuidado que o cara pode passar um ip de terceiros...
