- Cups (403 Forbidden)
Boa tarde
Tenho um servidor FC8, e estou tentando instalar uma impressora em rede nele, a opcao system-config-pinter nao funciona pois instalei so texto e ele pede algum server X, entao preciso inatalar essa impressoa via browser no cups, configurei o cupsd.conf e quando tento acessar, http://192.168.1.1:631 em qualquer extacao da na hora o erro
403 Forbidden
se alguem ja teve esse problema e resolveu, aguardo uma ajuda, segue o meu cupsd.conf pra analise...
# "$Id: cupsd.conf.in 7199 2008-01-08 00:16:30Z mike $"
# Sample configuration file for the Common UNIX Printing System (CUPS)
# scheduler. See "man cupsd.conf" for a complete description of this
# file.
# Log general information in error_log - change "info" to "debug" for
# troubleshooting...
#LogLevel info
# Administrator user group...
#SystemGroup sys root
# Only listen for connections from the local machine.
Allow From All
Listen *:631
Listen /var/run/cups/cups.sock
# Show shared printers on the local network.
Browsing On
BrowseOrder allow,deny
BrowseAllow all
# Default authentication type, when authentication is required...
#DefaultAuthType Basic
# Restrict access to the server...
#<Location />
# Order allow,deny
Allow From All
Allow From localhost
Allow From 192.168.1.0/254
#</Location>
# Restrict access to the admin pages...
<Location /admin>
Encryption Required
Order allow,deny
</Location>
# Restrict access to configuration files...
<Location /admin/conf>
AuthType Default
Require user @SYSTEM
Order allow,deny
</Location>
# Set the default printer/job policies...
<Policy default>
# Job-related operations must be done by the owner or an administrator...
<Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job CUPS-Move-Job>
Require user @OWNER @SYSTEM
Order deny,allow
</Limit>
# All administration operations require an administrator to authenticate...
<Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>
AuthType Default
Order deny,allow
</Limit>
# All printer operations require a printer operator to authenticate...
<Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After CUPS-Accept-Jobs CUPS-Reject-Jobs>
AuthType Default
Order deny,allow
</Limit>
# Only the owner or an administrator can cancel or authenticate a job...
<Limit Cancel-Job CUPS-Authenticate-Job>
Order deny,allow
</Limit>
<Limit All>
Order deny,allow
</Limit>
</Policy>
Alow From All
AuthType none
Browsing on
Browseprotocols cups
Listen *:631
# End of "$Id: cupsd.conf.in 7199 2008-01-08 00:16:30Z mike $".
