[lang=hr]minhas configurações! modem IP dinâmico ---- ------ -------------------- debian MikroTik router lula
ip-192.168.10.1/24 debian 192.168.20.10/30 ip
WLAN 192.168.100.1/24
lulas ip 192.168.20.1/30
MikroTik via ip gateway 192.168.20.1 dst 192.168.20.10
ip firewall add chain ação src src 192.168.20.0/30 dst ação nat endereço para o endereço 192.168.20.10 nat
ip firewall nat dst ação para abordar a 3128 192.168.20.10 portos no porto de interface tcp dst commenct 80 proxy
src o endereço IP 192.168.20.1 web proxy
portas-3128
proxy pai 192.168.20.10
porta proxy Pais 3126
squid log
2010/08/09 01:29:11| Process ID 5579
2010/08/09 01:29:11| With 1024 file descriptors available
2010/08/09 01:29:11| DNS Socket created at 0.0.0.0, port 60119, FD 7
2010/08/09 01:29:11| Adding nameserver 85.114.32.7 from /etc/resolv.conf
2010/08/09 01:29:11| helperOpenServers: Starting 20 'loader.php' processes
2010/08/09 01:29:11| Unlinkd pipe opened on FD 32
2010/08/09 01:29:11| Local cache digest enabled; rebuild/rewrite every 3600/3600 sec
2010/08/09 01:29:11| Swap maxSize 2048000 KB, estimated 157538 objects
2010/08/09 01:29:11| Target number of buckets: 7876
2010/08/09 01:29:11| Using 8192 Store buckets
2010/08/09 01:29:11| Max Mem size: 262144 KB
2010/08/09 01:29:11| Max Swap size: 2048000 KB
2010/08/09 01:29:11| Rebuilding storage in /var/spool/squid3/cache1 (DIRTY)
2010/08/09 01:29:11| Using Least Load store dir selection
2010/08/09 01:29:11| Set Current Directory to /var/spool/squid3
2010/08/09 01:29:11| Loaded Icons.
2010/08/09 01:29:11| Accepting transparently proxied HTTP connections at 0.0.0.0, port 3128, FD 33.
2010/08/09 01:29:11| HTCP Disabled.
2010/08/09 01:29:11| Ready to serve requests.
2010/08/09 01:29:11| WARNING: redirector #1 (FD 8) exited
2010/08/09 01:29:11| WARNING: redirector #3 (FD 10) exited
2010/08/09 01:29:11| WARNING: redirector #2 (FD 9) exited
2010/08/09 01:29:11| WARNING: redirector #4 (FD 11) exited
2010/08/09 01:29:11| WARNING: redirector #6 (FD 13) exited
2010/08/09 01:29:11| WARNING: redirector #7 (FD 14) exited
2010/08/09 01:29:11| WARNING: redirector #8 (FD 15) exited
2010/08/09 01:29:11| WARNING: redirector #9 (FD 16) exited
2010/08/09 01:29:11| WARNING: redirector #5 (FD 12) exited
2010/08/09 01:29:11| WARNING: redirector #10 (FD 17) exited
2010/08/09 01:29:11| WARNING: redirector #12 (FD 19) exited
2010/08/09 01:29:11| Too few redirector processes are running
FATAL: The redirector helpers are crashing too rapidly, need help!
help me![/lang]
