Código PHP:
#!/bin/bash
# firewall          Start/Stop firewalling rules.
# chkconfig: 35 11 92
# description: inicia/para as regras de firewall.
# processname: firewall
# config: /etc/firewall.conf
# pidfile: /var/run/firewall.pid
# Source function library.
. /etc/init.d/functions
PATH
="$PATH:/usr/local/bin"
RETVAL=0
# See how we were called.
prog="firewall"
funct_stop() {
iptables -t nat -F PREROUTING
iptables
-t nat -F POSTROUTING
iptables
-t nat -F TRANSPROXY
iptables
-F FORWARD
iptables
-F
iptables
-Z
iptables
-X
iptables
-t mangle -F FORWARD
iptables
-t mangle -F PREROUTING
iptables
-t mangle -F POSTROUTING
##iptables -t mangle -F CONNLIMIT
echo "0" > /proc/sys/net/ipv4/ip_forward
iptables
-P INPUT ACCEPT
iptables
-P OUTPUT ACCEPT
iptables
-P FORWARD DROP
start() {
        echo -
$"Starting $prog: "
bash -/etc/firewall.conf > /root/fwlog 2>&1
        fwports
        smtpservers
        redirs
        bloqueados
        RETVAL
        if [
$RETVAL -eq 0 ]; then
                echo_success
else
echo_failure
        fi
echo
ulimit -HSn 16384
stop() {
        echo -
$"Stopping $prog: "
funct_stop
        RETVAL
        if [
                echo_success
else
echo_failure
        fi
echo
rhstatus() {
iptables --n
restart() {
stop
        start
case
"$1" in
  start
start
stop)
stop
restart)
restart
reload)
reload
status)
rhstatus
condrestart)
/var/lock/subsys/firewall ] && restart || :
        echo $
"Usage: $0 {start|stop|status|restart|condrestart}"
exit 1
esac
obrigado
