Boa tarde!
Instalei e configure o squidGuard aqui no meu servidor proxy. O mesmo se encontra funcionando normalmente. Fui no arquivo sarg.conf e adicionei a linha squidguard_conf /usr/local/squidGuard/squidGuard.conf, para incluir os acessos nos relatórios. O problema é que, ao executar o sarg,quando chega na parte de leitura dos logs de acesso do squidGuard, ocorre o seguinte erro:
SARG: Reading squidGuard log file: /var/log/squidGuard/drugs.log
*** buffer overflow detected ***: sarg terminated
======= Backtrace ========
/lib64/libc.so.6(_fortify_fail+0x37)[0x7fdbe6d0bf37
======= Backtrace: =========
/lib64/libc.so.6(__fortify_fail+0x37)[0x7fdbe6d0bf37]
/lib64/libc.so.6(+0xe7ce0)[0x7fdbe6d09ce0]
sarg[0x421d60]
sarg[0x422498]
sarg[0x40d3dc]
sarg[0x4092dc]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x7fdbe6c40bfd]
sarg[0x401ef9]
======= Memory map: ========
00400000-0042e000 r-xp 00000000 08:01 264963 /usr/bi n/sarg
0062d000-0062e000 r--p 0002d000 08:01 264963 /usr/bi n/sarg
0062e000-00639000 rw-p 0002e000 08:01 264963 /usr/bi n/sarg
00639000-00805000 rw-p 00000000 00:00 0 [heap]
7fdbe6a0c000-7fdbe6a21000 r-xp 00000000 08:01 131215 /lib64/ libgcc_s.so.1
7fdbe6a21000-7fdbe6c20000 ---p 00015000 08:01 131215 /lib64/ libgcc_s.so.1
7fdbe6c20000-7fdbe6c21000 r--p 00014000 08:01 131215 /lib64/ libgcc_s.so.1
7fdbe6c21000-7fdbe6c22000 rw-p 00015000 08:01 131215 /lib64/ libgcc_s.so.1
7fdbe6c22000-7fdbe6d86000 r-xp 00000000 08:01 131154 /lib64/ libc-2.11.3.so
7fdbe6d86000-7fdbe6f85000 ---p 00164000 08:01 131154 /lib64/ libc-2.11.3.so
7fdbe6f85000-7fdbe6f89000 r--p 00163000 08:01 131154 /lib64/ libc-2.11.3.so
7fdbe6f89000-7fdbe6f8a000 rw-p 00167000 08:01 131154 /lib64/ libc-2.11.3.so
7fdbe6f8a000-7fdbe6f8f000 rw-p 00000000 00:00 0
7fdbe6f8f000-7fdbe6fad000 r-xp 00000000 08:01 134082 /lib64/ ld-2.11.3.so
7fdbe718d000-7fdbe7190000 rw-p 00000000 00:00 0
7fdbe71a7000-7fdbe71ac000 rw-p 00000000 00:00 0
7fdbe71ac000-7fdbe71ad000 r--p 0001d000 08:01 134082 /lib64/ ld-2.11.3.so
7fdbe71ad000-7fdbe71ae000 rw-p 0001e000 08:01 134082 /lib64/ ld-2.11.3.so
7fdbe71ae000-7fdbe71af000 rw-p 00000000 00:00 0
7fff3f44f000-7fff3f53f000 rw-p 00000000 00:00 0 [stack]
7fff3f5ff000-7fff3f600000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsysca ll]
/sbin/gera_relatorio: line 3: 3322 Aborted sarg -f /usr/local/s arg/sarg.conf -d $DATA-$DATA -p -x -z
Se os arquivos de log do squidGuard estiverem vazios, o sarg termina a execução normalmente. Será algo no formato do log do squidGuard? Notei que ele está salvando a data, dentro dos arquivos de log, no formato mm-dd-YYYY.
Alguém sabe o que pode estar acontecendo?
Desde já, agradeçoi pela ajuda de todos!
Vlw!
