Pessoal,
Estou com um erro no samba4.
Ele inicia, mas nenhuma maquina consegue conectar nele.
No log aparece o seguinte:
Código :
[2014/10/22 18:49:42,  0] ../source4/smbd/server.c:369(binary_smbd_main)  samba version 4.0.3 started.
  Copyright Andrew Tridgell and the Samba Team 1992-2012
[2014/10/22 18:49:43,  0] ../source4/smbd/server.c:475(binary_smbd_main)
  samba: using 'standard' process model
[2014/10/22 18:49:43,  2] ../source4/wrepl_server/wrepl_server.c:217(wreplsrv_load_partners)
  wreplsrv_load_partners: 0 partners found: wins_config_db seqnumber 1
[2014/10/22 18:49:43,  2] ../source4/dsdb/repl/drepl_partitions.c:116(dreplsrv_load_partitions)
  dreplsrv_partition[CN=Configuration,DC=pmvg,DC=local] loaded
  dreplsrv_partition[CN=Schema,CN=Configuration,DC=pmvg,DC=local] loaded
  dreplsrv_partition[DC=pmvg,DC=local] loaded
  dreplsrv_partition[DC=ForestDnsZones,DC=pmvg,DC=local] loaded
  dreplsrv_partition[DC=DomainDnsZones,DC=pmvg,DC=local] loaded
[2014/10/22 18:49:43,  1] ../source4/kdc/db-glue.c:1956(samba_kdc_setup_db_ctx)
  samba_kdc_fetch: could not find own KRBTGT in DB: (null)
[2014/10/22 18:49:43,  0] ../source4/smbd/service_task.c:35(task_server_terminate)
  task_server_terminate: [kdc: hdb_samba4_create_kdc (setup KDC database) failed]
[2014/10/22 18:49:43,  0] ../source4/smbd/server.c:210(samba_terminate)
  samba_terminate: kdc: hdb_samba4_create_kdc (setup KDC database) failed
[2014/10/22 18:49:43,  2] ../source4/dsdb/kcc/kcc_service.c:127(kccsrv_load_partitions)
  kccsrv_partition[DC=pmvg,DC=local] loaded
  kccsrv_partition[CN=Configuration,DC=pmvg,DC=local] loaded
  kccsrv_partition[CN=Schema,CN=Configuration,DC=pmvg,DC=local] loaded
  kccsrv_partition[DC=DomainDnsZones,DC=pmvg,DC=local] loaded
  kccsrv_partition[DC=ForestDnsZones,DC=pmvg,DC=local] loaded
Alguem ai poderia me ajudar a corrigir esse erro?
