    Question Isolamento entre redes com vlan
    Amigos, boa noite
    [DIAGRAMA DA REDE]
Nome:	         Unifi Controller Network.png
Visualizações:	269
Tamanho: 	73,2 KB
    Configuração da RB493AH
    Código :
    [SIZE=4][I][FONT=courier new]/interface bridge
    add mtu=1520 name=lan
    add mtu=1516 name=vlan10
    add mtu=1516 name=vlan20
    /interface vlan
    add interface=ether3 name=vlan10-ether3 vlan-id=10
    add interface=ether3 name=vlan20-ether3 vlan-id=20
    /ip neighbor discovery
    set vlan10-ether3 discover=no
    set vlan20-ether3 discover=no
    /ip dhcp-server option
    add code=43 name=unifi value=0xC0A803FE
    /ip pool
    add name=dhcpd_lan ranges=10.0.0.11-10.0.0.254
    add name=dhcpd_manage ranges=10.0.10.11-10.0.10.254
    add name=dhcpd_guest ranges=10.0.20.11-10.0.20.254
    /ip dhcp-server
    add address-pool=dhcpd_lan disabled=no interface=lan name=dhcpd_lan
    add address-pool=dhcpd_manage disabled=no interface=vlan10 name=dhcpd_manage
    add address-pool=dhcpd_guest disabled=no interface=vlan20 name=dhcpd_guest
    /interface bridge port
    add bridge=lan interface=ether2
    add bridge=lan interface=ether3
    add bridge=vlan10 interface=vlan10-ether3
    add bridge=vlan20 interface=vlan20-ether3
    /ip address
    add address=10.0.0.3/24 interface=lan network=10.0.0.0
    add address=10.0.10.3/24 interface=vlan10 network=10.0.10.0
    add address=10.0.20.3/24 interface=vlan20 network=10.0.20.0
    /ip dhcp-server network
    add address=10.0.0.0/24 dhcp-option=unifi dns-server=10.0.0.3 gateway=10.0.0.3
    add address=10.0.10.0/24 dhcp-option=unifi dns-server=10.0.10.3 gateway=10.0.10.3
    add address=10.0.20.0/24 dhcp-option=unifi dns-server=10.0.20.3 gateway=10.0.20.3
    /ip dns
    set allow-remote-requests=yes
    [/FONT][/I][/SIZE]
    GRUPO A - TI
    10.0.10.0/24
    GRUPO B - Demais redes
    10.0.0.0/24
    10.0.20.0/24
    Vamos ao X da questão, preciso isolar as redes do grupo b entre eles, e deixar a rede do grupo a acessando tudo, já pesquisei no google como isolar a rede mais não obtive sucesso, alguém poderia me ajuda a resolver este pequeno problema?
    Desde já, agradeço ajuda.
    Alex Rock Avatar de alexrock
    Jan 2006
    S. J. do Rio Preto-SP
    Padrão Re: Isolamento entre redes com vlan
    Bloqueia via firewall o forward ebtre elas.
    Enviado de meu LG-K350 usando Tapatalk
    Citação Postado originalmente por alexrock Ver Post
    Alexrock,
    Eu ja fiz o que vc pensou, mais nao funcionou, ou seja, a regra ou bloqueia tudo ou abre tudo.
    Obrigado
    Jan 2006
    Passa as regras que você usou.
    aqui eu uso em uma das redes minha o serviço de pppoe para mim essa serve
    /interface bridge filter add action=accept chain=forward comment=PPPOE-SESSION disabled=no mac-protocol=0x8864
    /interface bridge filter add action=accept chain=forward comment=PPPOE-DISCOVERY disabled=no mac-protocol=0x8863
    /interface bridge filter add action=drop chain=forward comment=DROPA-RESTO disabled=no
    /ip firewall filter add chain=forward src-address=10.0.20.0/24 dst-address=10.0.20.0/24 action=drop comment="bloqueio trafico entre cliente" disabled=no
    Jan 2006
    Citação Postado originalmente por Good_speed Ver Post
    Essa regra não faz sentido. Origem e destino tem que ser redes diferentes.
    Vamo lá irmão:
    /ip firewall filter
    add chain=forward connection-state=established comment="aceita sempre que for uma conexão estabelecida"
    /ip firewall filter
    add chain=forward connection-state=related comment="aceita sempre que for uma conexão relacionada"
    /ip firewall filter add chain=forward src-address=10.0.10.0/24 action=accept comment="aceita tudo quando a origem é a rede 10.0.10.0/24" disabled=no
    /ip firewall filter add chain=forward src-address=10.0.0.0/24 dst-address=10.0.0.0/8 action=drop comment="bloqueia tudo quando a rede de origem for 10.0.0.0/24 destinado a qualquer IP da classe 10/8" disabled=no
    /ip firewall filter add chain=forward src-address=10.0.20.0/24 dst-address=10.0.0.0/8 action=drop comment="bloqueia tudo quando a rede de origem for 10.0.20.0/24 destinado a qualquer IP da classe 10/8" disabled=no
    Enviado via XT1580 usando UnderLinux App
    Esses dias tive o mesmo problema ao fazer bloqueio entre redes. Tinha as rede A, B e C e precisava isolar B e C. Pesquisei na net e até encontrei alguns scripts, porém não funcionava. Todos os scripts que vi usava somente o forward para fazer bloqueio e não funcionava. A única forma que funcionou, foi a seguinte:
    SCRIPT
    add action=drop chain=input src-address=REDE_C dst-address=REDE_B in-interface=REDE_C
    add action=drop chain=forward src-address=REDE_C dst-address=REDE_B in-interface=REDE_C
    add action=drop chain=input src-address=REDE_B dst-address=REDE_C in-interface=REDE_B
    add action=drop chain=forward src-address=REDE_B dst-address=REDE_C in-interface=REDE_B
