Alguém aí lembra da monha última mensagem sobre o kernel, faz nuito tempo, mas tá.
Bom, finalmente eu tive um tempinho d sentar-me afrente desse computador e tentar denovo, e adivinhem só, eu naum consegui denovo, mas consegui retirar a mensagem de erro e copiá-la p/ um arquivo.
E la vai ela:
gcc -Wp,-MD,drivers/video/sis/.sis_main.o.d -D__KERNEL__ -Iinclude -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=athlon -Iinclude/asm-i386/mach-default -fomit-frame-pointer -nostdinc -iwithprefix include -DMODULE -DKBUILD_BASENAME=sis_main -DKBUILD_MODNAME=sisfb -DEXPORT_SYMTAB -c -o drivers/video/sis/sis_main.o drivers/video/sis/sis_main.c
drivers/video/sis/sis_main.c:49:25: video/fbcon.h: Arquivo ou diretrio n� encontrado
drivers/video/sis/sis_main.c:50:30: video/fbcon-cfb8.h: Arquivo ou diretrio n� encontrado
drivers/video/sis/sis_main.c:51:31: video/fbcon-cfb16.h: Arquivo ou diretrio n� encontrado
drivers/video/sis/sis_main.c:52:31: video/fbcon-cfb24.h: Arquivo ou diretrio n� encontrado
drivers/video/sis/sis_main.c:53:31: video/fbcon-cfb32.h: Arquivo ou diretrio n� encontrado
In file included from drivers/video/sis/sis_main.c:57:
drivers/video/sis/sis_main.h:251: warning: excess elements in array initializer
drivers/video/sis/sis_main.h:251: warning: (near initialization for `default_var.reserved&acute
drivers/video/sis/sis_main.h:281: redeclaration of `enum _VGA_ENGINE´
drivers/video/sis/sis_main.h:282: conflicting types for `UNKNOWN_VGA´
include/linux/sisfb.h:47: previous declaration of `UNKNOWN_VGA´
drivers/video/sis/sis_main.h:283: conflicting types for `SIS_300_VGA´
include/linux/sisfb.h:48: previous declaration of `SIS_300_VGA´
drivers/video/sis/sis_main.h:284: conflicting types for `SIS_315_VGA´
include/linux/sisfb.h:49: previous declaration of `SIS_315_VGA´
drivers/video/sis/sis_main.c: In function `sis_get_glyph´:
drivers/video/sis/sis_main.c:250: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c:250: (Each undeclared identifier is reported only once
drivers/video/sis/sis_main.c:250: for each function it appears in.)
drivers/video/sis/sis_main.c:259: warning: implicit declaration of function `fontheight´
drivers/video/sis/sis_main.c:260: warning: implicit declaration of function `fontwidth´
drivers/video/sis/sis_main.c:263: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:265: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:267: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c: In function `sisfb_set_disp´:
drivers/video/sis/sis_main.c:657: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c:666: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:667: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:668: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:669: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:670: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:671: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:672: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:673: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:674: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:675: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:677: warning: implicit declaration of function `save_flags´
drivers/video/sis/sis_main.c:704: `fbcon_dummy´ undeclared (first use in this function)
drivers/video/sis/sis_main.c:707: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:708: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:709: warning: implicit declaration of function `restore_flags´
drivers/video/sis/sis_main.c:711: dereferencing pointer to incomplete type
drivers/video/sis/sis_main.c:711: `SCROLL_YREDRAW´ undeclared (first use in this function)
drivers/video/sis/sis_main.c:712: invalid use of undefined type `struct display_switch´
drivers/video/sis/sis_main.c:712: `fbcon_redraw_bmove´ undeclared (first use in this function)
drivers/video/sis/sis_main.c: In function `sisfb_do_install_cmap´:
drivers/video/sis/sis_main.c:721: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c: In function `sisfb_get_fix´:
drivers/video/sis/sis_main.c:2313: structure has no member named `modename´
drivers/video/sis/sis_main.c: In function `sisfb_get_var´:
drivers/video/sis/sis_main.c:2354: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c: In function `sisfb_set_var´:
drivers/video/sis/sis_main.c:2370: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c:2384: structure has no member named `changevar´
drivers/video/sis/sis_main.c:2385: structure has no member named `changevar´
drivers/video/sis/sis_main.c:2394: warning: implicit declaration of function `vc_resize_con´
drivers/video/sis/sis_main.c: In function `sisfb_get_cmap´:
drivers/video/sis/sis_main.c:2407: warning: implicit declaration of function `fb_get_cmap´
drivers/video/sis/sis_main.c:2408: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c: In function `sisfb_set_cmap´:
drivers/video/sis/sis_main.c:2421: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c: At top level:
drivers/video/sis/sis_main.c:2563: unknown field `fb_get_fix´ specified in initializer
drivers/video/sis/sis_main.c:2563: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c:2564: unknown field `fb_get_var´ specified in initializer
drivers/video/sis/sis_main.c:2564: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c:2565: unknown field `fb_set_var´ specified in initializer
drivers/video/sis/sis_main.c:2565: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c:2566: unknown field `fb_get_cmap´ specified in initializer
drivers/video/sis/sis_main.c:2566: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c:2567: unknown field `fb_set_cmap´ specified in initializer
drivers/video/sis/sis_main.c:2567: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c:2570: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c:2572: warning: initialization from incompatible pointer type
drivers/video/sis/sis_main.c: In function `sisfb_switch´:
drivers/video/sis/sis_main.c:2588: `fb_display´ undeclared (first use in this function)
drivers/video/sis/sis_main.c: In function `sisfb_setup´:
drivers/video/sis/sis_main.c:2650: structure has no member named `fontname´
drivers/video/sis/sis_main.c:2664: structure has no member named `fontname´
drivers/video/sis/sis_main.c: In function `sisfb_init´:
drivers/video/sis/sis_main.c:2742: structure has no member named `modename´
drivers/video/sis/sis_main.c:2774: structure has no member named `modename´
drivers/video/sis/sis_main.c:3346: structure has no member named `changevar´
drivers/video/sis/sis_main.c:3357: structure has no member named `disp´
drivers/video/sis/sis_main.c:3358: structure has no member named `switch_con´
drivers/video/sis/sis_main.c:3359: structure has no member named `updatevar´
drivers/video/sis/sis_main.c:3394: structure has no member named `modename´
include/linux/pci.h: At top level:
drivers/video/sis/sis_main.h:219: storage size of `disp´ isn´t known
drivers/video/sis/sis_main.h:223: storage size of `sisfb_sw´ isn´t known
drivers/video/sis/sis_main.h:267: warning: `fbcon_cmap´ defined but not used
drivers/video/sis/sis_main.h:275: warning: `currcon´ defined but not used
make[3]: ** [drivers/video/sis/sis_main.o] Erro 1
make[2]: ** [drivers/video/sis] Erro 2
make[1]: ** [drivers/video] Erro 2
make: ** [drivers] Erro 2
Eu sei q ela naum é exatamente pequena, e é por isso q eu peço a ajuda d vcs. Pelo q eu netendi, ela c refere ao driver da minha placa d vídeo.
Por favor, algué aí tem alguma luz sobre como eu devo fazer p/ conseguir compilar este kernel!!!!!!!!!!!! <IMG SRC="images/forum/icons/icon27.gif">
