- PLACA DE REDE
PLACA DE REDE
ESTOU COM UM PROBLEMA MEIO IDIOTA:
MINHA DIST É RH 9
TENHO DUAS 3COM 905C NA MÁQUINA
AS DUAS 192.168.0.X/24
SÓ QUE QUANDO VOU PINGAR SÓ PING POR UMA OU SEJA PELA ETH1
A ETH0 NÃO PING (TUDO SAI E ENTRA PELA ETH1)
SE EU DESABILITAR A ETH1 AI SIM A ETH0 PASSA A PINGAR
SE EU COLAR 4 PLACAS DE REDE SÓ A QUE VAI PINGAR É A ETH4
DOU UM EXEMPLO
MEU MAILSERVER É 192.168.0.17
MEU WEBSERVER É 192.168.0.26
MEU ROUTER CONFIGUREI PARA OQ VIER PELA 25 E 110 VAI PARA O 17
E 80 PARA O 26
SE EU COLACAR RH 9 COM DUAS PLACAS COM OS IPS:
ETH0 192.168.0.17
ETH1 192.168.0.26
ELE RESPONDE DIREITO MAS O TRÁFEGO SÓ VEM PELA ETH1
SE EU PEGAR O CABO E COLOCAR NA ETH0 NA ENTRA E NADA SAI
SE EU PINGAR DE DENTRO DO HOST AS DUAS RESPONDEM DIREITO SE EU PINGAR PARA FORA SÓ A ETH1 VAI RESPONDER.
NO RH 7.3 ISSO NÃO ACONTECE AS DUAS FUNCIONAM SIMULTANEAMENTE
Q M É ESSA!!
