tentei configurar o me lilo para dar boot pelo cd, uso mandrake 9.2 e sempre usava o lilo que ja vinha configrado pelo mandrake. no kde, quando fui tentar altera-lo tive a seguinte mensagem:
fatal not a number: "padrão", bom coloquei entao o numero 788 e agora tenho a seguinte mensagem:
O LILI disse: a configuração NÃO está OK
LILO version 22.5.7.2 (test mode), Copyright (C) 1992-1998 Werner Almesberger
Development beyond version 21 Copyright (C) 1999-2003 John Coffman
Released 20-Aug-2003, and compiled at 16:45:54 on Sep 18 2003
Reading boot sector from /dev/hda
Using GRAPHIC secondary loader
Calling map_insert_data
Mapping message file /boot/message -> message-graphic
Calling map_insert_file
Boot image: /boot/vmlinuz -> vmlinuz-2.4.22-10mdk
Mapping RAM disk /boot/initrd.img -> initrd-2.4.22-10mdk.img
Added linux *
Added failsafe
Boot other: /dev/hda1, on /dev/hda, loader CHAIN
Added windows98
Boot image: /dev/hda1 -> ide/host0/bus0/target0/lun0/part1
Fatal: Kernel doesn't support initial RAM disks
abaixo segue como esta meuarquivo lilo.conf:
boot="/dev/hda"
map=/boot/map
vga="padrão"
default="linux"
keytable=/boot/br-abnt2.klt
prompt
nowarn
timeout="600"
message=/boot/message
menu-scheme=wb:bw:wb:bw
image="/boot/vmlinuz"
label="linux"
root="/dev/hda5"
initrd="/boot/initrd.img"
append="devfs=mount hdc=ide-scsi acpi=ht resume=/dev/hda2"
read-only
label="failsafe"
root="/dev/hda5"
append="failsafe devfs=nomount hdc=ide-scsi acpi=ht resume=/dev/hda2"
read-only
other=/dev/hda1
label="windows98"
table=/dev/hda
image="/dev/hda1"
root="/dev/hda5"
other=/dev/fd0
label="floppy"
unsafe
image="/dev/fd0"
root="/dev/hda5"
other=/dev/hdd
label="cdrom"
image="/dev/hdd"
root="/dev/hda5"
agradeco a quem poder ajudar
