- Postfix + Amavisd-new
Pessoal,
estou implementando o amavisd-new junto com o postfix, mas quando starto o amavis, aparece os seguintes erros no log:
Jul 22 20:54:47 webserver amavis[15778]: starting. /usr/local/sbin/amavisd at webserver.master amavisd-new-20040701 (2.0), Unicode aware
Jul 22 20:54:47 webserver amavis[15778]: user=, EUID: 0 (0); group=, EGID: 0 31 20 5 4 3 2 0 0 (0 31 20 5 4 3 2 0 0)
Jul 22 20:54:47 webserver amavis[15778]: Perl version 5.008004
Jul 22 20:54:48 webserver amavis[15779]: FATAL: It is possible to change EUID from 1006 to root, ABORTING!
Jul 22 20:54:48 webserver amavis[15779]: FATAL: Perhaps you forgot to patch the Net::Server - see:
Jul 22 20:54:48 webserver amavis[15779]: FATAL: http://www.ijs.si/software/amavisd/#net-server-sec
Jul 22 20:54:48 webserver amavis[15779]: FATAL: or start as non-root, e.g. by su(1) or using option -u user
Jul 22 20:54:48 webserver amavis[15779]: TROUBLE in pre_loop_hook: EUID problem, ABORTING at /usr/local/sbin/amavisd line 5339.
Já criei o usuário para o amavis, mas ele tenta startar como root e não consegue.
Alguém tem alguma idéia?
Valeu!
