Ola a todos!
Eu estou copilando o kernel do conecitiva 9.0 2.4.21-31301U90_4cl antes de
começar a copilar eu execudo o make clean e depois no make menuconfig
seleciono somente o modulo para suportar 4 G de Memoria. e salvo e saio,
apois isto executo o comando make dep, make bzImage e depois make modules e
aki que da o problema quando executo este comando (make modules) da a
seguinte mensagem de erro:
eni.c:1629: invalid suffix on integer constant
eni.c:1629: called object is not a function
eni.c:1629: invalid suffix on floating constant
eni.c:1630: invalid suffix on integer constant
eni.c:1630: called object is not a function
eni.c:1630: invalid suffix on floating constant
eni.c:1633: invalid suffix on integer constant
eni.c:1633: called object is not a function
eni.c:1633: invalid suffix on floating constant
eni.c:1635: invalid suffix on integer constant
eni.c:1635: called object is not a function
eni.c:1635: invalid suffix on floating constant
eni.c:1642: invalid suffix on integer constant
eni.c:1642: called object is not a function
eni.c:1642: invalid suffix on floating constant
eni.c:1644: invalid suffix on integer constant
eni.c:1644: called object is not a function
eni.c:1644: invalid suffix on floating constant
eni.c:1645: invalid suffix on integer constant
eni.c:1645: called object is not a function
eni.c:1645: invalid suffix on floating constant
eni.c:1648: invalid suffix on integer constant
eni.c:1648: called object is not a function
eni.c:1648: invalid suffix on floating constant
eni.c:1650: invalid suffix on integer constant
eni.c:1650: called object is not a function
eni.c:1650: invalid suffix on floating constant
eni.c:1654: invalid suffix on integer constant
eni.c:1654: called object is not a function
eni.c:1654: invalid suffix on floating constant
eni.c:1656: invalid suffix on integer constant
eni.c:1656: called object is not a function
eni.c:1656: invalid suffix on floating constant
eni.c:1657: invalid suffix on integer constant
eni.c:1657: called object is not a function
eni.c:1657: invalid suffix on floating constant
eni.c:1660: invalid suffix on integer constant
eni.c:1660: called object is not a function
eni.c:1660: invalid suffix on floating constant
eni.c:1662: invalid suffix on integer constant
eni.c:1662: called object is not a function
eni.c:1662: invalid suffix on floating constant
eni.c:1666: invalid suffix on integer constant
eni.c:1666: called object is not a function
eni.c:1666: invalid suffix on floating constant
eni.c:1668: invalid suffix on integer constant
eni.c:1668: called object is not a function
eni.c:1668: invalid suffix on floating constant
eni.c:1670: invalid suffix on integer constant
eni.c:1670: called object is not a function
eni.c:1670: invalid suffix on floating constant
eni.c:1673: invalid suffix on integer constant
eni.c:1673: warning: null format string
eni.c:1674: called object is not a function
eni.c: In function `eni_do_init':
eni.c:1713: invalid suffix on integer constant
eni.c:1713: called object is not a function
eni.c:1715: invalid suffix on integer constant
eni.c:1715: warning: null format string
eni.c:1716: called object is not a function
eni.c:1719: `f23d8795' undeclared (first use in this function)
eni.c:1721: called object is not a function
eni.c:1722: invalid suffix on integer constant
eni.c:1722: warning: null format string
eni.c:1723: called object is not a function
eni.c:1726: invalid suffix on integer constant
eni.c:1726: warning: null format string
eni.c:1727: called object is not a function
eni.c:1729: invalid suffix on integer constant
eni.c:1729: warning: null format string
eni.c:1729: called object is not a function
eni.c:1730: invalid suffix on integer constant
eni.c:1730: warning: null format string
eni.c:1731: called object is not a function
eni.c:1740: invalid suffix on integer constant
eni.c:1740: warning: null format string
eni.c:1740: called object is not a function
eni.c:1741: invalid suffix on integer constant
eni.c:1741: warning: null format string
eni.c:1743: called object is not a function
eni.c:1765: invalid suffix on integer constant
eni.c:1765: warning: null format string
eni.c:1765: called object is not a function
eni.c:1768: invalid suffix on integer constant
eni.c:1768: warning: null format string
eni.c:1768: called object is not a function
eni.c:1769: invalid suffix on integer constant
eni.c:1769: warning: null format string
eni.c:1770: called object is not a function
eni.c:1776: invalid suffix on integer constant
eni.c:1776: warning: null format string
eni.c:1776: called object is not a function
eni.c:1777: invalid suffix on integer constant
eni.c:1777: warning: null format string
eni.c:1777: called object is not a function
eni.c:1778: invalid suffix on integer constant
eni.c:1778: warning: null format string
eni.c:1780: called object is not a function
eni.c: In function `eni_start':
eni.c:1793: invalid suffix on integer constant
eni.c:1793: called object is not a function
eni.c:1794: invalid suffix on integer constant
eni.c:1794: warning: null format string
eni.c:1795: called object is not a function
eni.c:1799: invalid suffix on integer constant
eni.c:1799: called object is not a function
eni.c:1800: `f23d8795' undeclared (first use in this function)
eni.c:1802: called object is not a function
eni.c:1803: invalid suffix on integer constant
eni.c:1803: warning: null format string
eni.c:1804: called object is not a function
eni.c:1811: invalid suffix on integer constant
eni.c:1812: called object is not a function
eni.c:1813: invalid suffix on integer constant
eni.c:1813: warning: null format string
eni.c:1814: called object is not a function
eni.c:1827: `a5808bbf' undeclared (first use in this function)
eni.c:1827: called object is not a function
eni.c:1832: invalid suffix on integer constant
eni.c:1833: called object is not a function
eni.c:1835: invalid suffix on integer constant
eni.c:1835: warning: null format string
eni.c:1836: called object is not a function
eni.c: In function `eni_close':
eni.c:1876: invalid suffix on integer constant
eni.c:1876: called object is not a function
eni.c: In function `eni_open':
eni.c:1941: invalid suffix on integer constant
eni.c:1941: called object is not a function
eni.c: In function `eni_change_qos':
eni.c:1978: invalid suffix on integer constant
eni.c:1978: called object is not a function
eni.c: In function `eni_ioctl':
eni.c:2015: invalid suffix on integer constant
eni.c:2015: warning: null format string
eni.c:2016: called object is not a function
eni.c:2025: invalid suffix on integer constant
eni.c:2025: called object is not a function
eni.c:2037: invalid suffix on integer constant
eni.c:2037: called object is not a function
eni.c: In function `eni_send':
eni.c:2074: invalid suffix on integer constant
eni.c:2074: warning: null format string
eni.c:2074: called object is not a function
eni.c: In function `eni_proc_read':
eni.c:2130: invalid suffix on integer constant
eni.c:2132: called object is not a function
eni.c:2134: invalid suffix on integer constant
eni.c:2175: called object is not a function
eni.c:2177: invalid suffix on integer constant
eni.c:2178: called object is not a function
eni.c:2184: invalid suffix on integer constant
eni.c:2189: called object is not a function
eni.c:2192: invalid suffix on integer constant
eni.c:2193: called object is not a function
eni.c:2200: invalid suffix on integer constant
eni.c:2200: called object is not a function
eni.c:2202: invalid suffix on integer constant
eni.c:2206: called object is not a function
eni.c:2207: invalid suffix on integer constant
eni.c:2207: called object is not a function
eni.c:2210: invalid suffix on integer constant
eni.c:2211: called object is not a function
eni.c:2221: invalid suffix on integer constant
eni.c:2223: called object is not a function
eni.c: In function `eni_init_one':
eni.c:2255: invalid suffix on integer constant
eni.c:2255: called object is not a function
eni.c:2260: invalid suffix on integer constant
eni.c:2260: called object is not a function
eni.c:2286: invalid suffix on integer constant
eni.c:2286: called object is not a function
eni.c: In function `eni_init':
eni.c:2322: invalid suffix on integer constant
eni.c:2322: warning: null format string
eni.c:2323: called object is not a function
eni.c:2326: invalid suffix on floating constant
eni.c:2326: called object is not a function
eni.c:2327: `e8061e13' undeclared (first use in this function)
eni.c:2327: called object is not a function
/usr/src/linux-2.4.21-31301U90_4cl/include/linux/skbuff.h: In function
`kunmap_s
kb_frag':
/usr/src/linux-2.4.21-31301U90_4cl/include/linux/skbuff.h:1129: warning: asm
ope
rand 1 probably doesn't match constraints
make[2]: ** [eni.o] Erro 1
make[2]: Leaving directory `/usr/src/linux-2.4.21-31301U90_4cl/drivers/atm'
make[1]: ** [_modsubdir_atm] Erro 2
make[1]: Leaving directory `/usr/src/linux-2.4.21-31301U90_4cl/drivers'
make: ** [_mod_drivers] Erro 2
Alguem poderia me ajudar a solucionar esta problema o que poderá ser pois so
esta faltando fazer o kernel suportar 4 G de ram para terminar o ambiente de
alta disponibilidade.
Desde ja agradeço!
