Olá pessoal,
estou tentando instalar um servidor de fax aqui na minha maq.
, baixei o arquivo .tar do hylafax e segui os passos abaixo (como no tutorial)
# tar zxvf hylafax-xxx.tar.gz
# cd hylafax-xxx
# ./configure
# make; make install
este é o final do ./configure
... checking TIFF library version
Missing TIFF Library.
Compilation of the following test program failed:
#include <stdio.h>
#include "tiffio.h"
main()
printf( "header_ver=%d lib_ver=%s", TIFFLIB_VERSION, TIFFGetVersion() );
exit(0);
TIFFINC=/usr/local/include
LIBTIFF=-L/usr/local/lib -ltiff
Verify that you have the TIFFINC and LIBTIFF configuration parameters
set correctly for your system (see above) and that any environment
variables are setup that are needed to locate a libtiff DSO at runtime
(e.g. LD_LIBRARY_PATH). Also be sure that any relative pathnames are
made relative to the top of the build area.
Unrecoverable error! Once you've corrected the problem rerun this script.
e o comando make tambem dá erro
qualquer luz já ajuda
obrigado
