Boa noite, alquem já programou em Allegro no Fedora4 ??
Pq eu instalei allegro-4.0.3-13.i386.rpm e não estou conseguinto compilar. Allegro é uma biblioteca para c/c++
Quando eu digito: gcc Jhiad.c `allegro-config --libs` dá o seguinte erro:
bash: allegro-config: command not found
Jhiad.c:1:20: error: allegro.h: Arquivo ou diretório não encontrado
Jhiad.c: In function ‘main’:
Jhiad.c:19: error: ‘GFX_AUTODETECT’ undeclared (first use in this function)
Jhiad.c:19: error: (Each undeclared identifier is reported only once
Jhiad.c:19: error: for each function it appears in.)
Jhiad.c:20: error: ‘screen’ undeclared (first use in this function)
Jhiad.c:22: error: ‘BITMAP’ undeclared (first use in this function)
Jhiad.c:22: error: ‘teste’ undeclared (first use in this function)
Jhiad.c:24: error: ‘NULL’ undeclared (first use in this function)
Jhiad.c:26: error: ‘key’ undeclared (first use in this function)
Jhiad.c:26: error: ‘KEY_ESC’ undeclared (first use in this function)
Jhiad.c:28: error: ‘KEY_RIGHT’ undeclared (first use in this function)
Jhiad.c:34: error: ‘font’ undeclared (first use in this function)
Jhiad.c:38: error: ‘KEY_LEFT’ undeclared (first use in this function)
Jhiad.c:47: error: ‘KEY_DOWN’ undeclared (first use in this function)
Jhiad.c:56: error: ‘KEY_UP’ undeclared (first use in this function)
Jhiad.c: At top level:
Jhiad.c:75: warning: data definition has no type or storage class
Eu estou achando que é por causa do bash, pq eu estou usando o Shell. Alguem sabe como eu configuro o shell para "achar" o Allegro??
Muito obrigado, Fábio
