Alguem podeira me informar se estas mensagem de aviso q esta no log o heartbeat e normal? Se não o que pode ser?
Desde ja agradeço
heartbeat[2297]: 2006/03/22_18:15:48 info: remote resource transition completed.
heartbeat[2297]: 2006/03/22_18:15:48 info: Local Resource acquisition completed. (none)
heartbeat[2297]: 2006/03/22_18:15:48 info: Initial resource acquisition complete (T_RESOURCES(them))
heartbeat[2297]: 2006/03/22_18:15:48 WARN: G_CH_dispatch: Dispatch function for read child took too long to execute: 1880 ms (GSource: 0x67c908)
heartbeat[2297]: 2006/03/22_18:15:48 WARN: G_SIG_dispatch: Dispatch function for SIGCHLD was delayed 6920 ms before being called (GSource: 0x676c28)
heartbeat[2297]: 2006/03/22_18:15:48 info: G_SIG_dispatch: started at 429414332 should have started at 429413640
heartbeat[2297]: 2006/03/22_18:15:48 info: Exiting write_hostcachedata process 2376 returned rc 0.
heartbeat[2297]: 2006/03/22_18:15:50 WARN: G_SIG_dispatch: Dispatch function for SIGCHLD took too long to execute: 360 ms (GSource: 0x676c28)
heartbeat[2297]: 2006/03/22_18:15:50 WARN: Gmain_timeout_dispatch: Dispatch function for hb_pop_deadtime was delayed 4720 ms before being called (GSource: 0x677a08)
heartbeat[2297]: 2006/03/22_18:15:50 info: Gmain_timeout_dispatch: started at 429414511 should have started at 429414039
heartbeat[2297]: 2006/03/22_18:15:50 WARN: Gmain_timeout_dispatch: Dispatch function for hb_pop_deadtime took too long to execute: 550 ms (GSource: 0x677a08)
heartbeat[2297]: 2006/03/22_18:15:51 WARN: Gmain_timeout_dispatch: Dispatch function for check for signals was delayed 8550 ms before being called (GSource: 0x67d0e8)
heartbeat[2297]: 2006/03/22_18:15:51 info: Gmain_timeout_dispatch: started at 429414594 should have started at 429413739
heartbeat[2297]: 2006/03/22_18:15:52 WARN: Gmain_timeout_dispatch: Dispatch function for send_reqnodes_msg was delayed 9500 ms before being called (GSource: 0x683f38)
heartbeat[2297]: 2006/03/22_18:15:52 info: Gmain_timeout_dispatch: started at 429414690 should have started at 429413740
heartbeat[2297]: 2006/03/22_18:15:52 WARN: Gmain_timeout_dispatch: Dispatch function for send local status was delayed 2370 ms before being called (GSource: 0x67cae8)
heartbeat[2297]: 2006/03/22_18:15:52 info: Gmain_timeout_dispatch: started at 429414769 should have started at 429414532
heartbeat[2297]: 2006/03/22_18:15:52 WARN: Gmain_timeout_dispatch: Dispatch function for update msgfree count wa
