Caros amigos, configurei o DNS e o DHCP para que hovesse a atualização dinâmica do meu dns, mas isso não ocorreu. O meu DNS funcina normalmente e o DHCP também, mas eles não se cominicam "/etc/named.conf:18: couldn't add command channel 127.0.0.1#953: address in use" acho que essa mensagem é a resposta do problema! vou colocar abaixo o log,
Na ocasião dos testes o arquivo
-rwxr-xr-x 1 named named 1010 Jul 2 19:57 named.conf*
-rw------- 1 root root 1151 Jul 2 19:35 dhcpd.conf
Arquivo de log
Jul 3 11:06:58 TesteServer named[2733]: loading configuration from '/etc/named.conf'
Jul 3 11:06:58 TesteServer named[2733]: listening on IPv4 interface lo, 127.0.0.1#53
Jul 3 11:06:58 TesteServer named[2733]: binding TCP socket: address in use
Jul 3 11:06:58 TesteServer named[2733]: listening on IPv4 interface eth0, 10.90.9.10#53
Jul 3 11:06:58 TesteServer named[2733]: zone 'ascnet.com.br' allows updates by IP address, which is insecure
Jul 3 11:06:58 TesteServer named[2733]: zone '9.90.10.in-addr.arpa' allows updates by IP address, which is insecure
Jul 3 11:06:58 TesteServer named[2733]: /etc/named.conf:18: couldn't add command channel 127.0.0.1#953: address in use
Jul 3 11:06:58 TesteServer named[2733]: couldn't open pid file '/var/run/named/named.pid': File exists
Jul 3 11:06:58 TesteServer named[2733]: exiting (due to early fatal error)
