Pessoal, estou tentando dar o bendito MAKE SETUP CHECK no meu qmail pra compila-lo, e o seguinte erro aparece:
( ( ./compile tryvfork.c && ./load tryvfork ) >/dev/null \
2>&1 \
&& cat fork.h2 || cat fork.h1 ) > fork.h
rm -f tryvfork.o tryvfork
./compile qmail-local.c
qmail-local.c:1:23: sys/types.h: Arquivo ou diret?rio n?o encontrado
qmail-local.c:2:22: sys/stat.h: Arquivo ou diret?rio n?o encontrado
qmail-local.c: In function `maildir_child´:
qmail-local.c:85: storage size of `st´ isn´t known
qmail-local.c: In function `checkhome´:
qmail-local.c:313: storage size of `st´ isn´t known
qmail-local.c: In function `qmeox´:
qmail-local.c:329: storage size of `st´ isn´t known
qmail-local.c: In function `qmeexists´:
qmail-local.c:348: storage size of `st´ isn´t known
qmail-local.c:361: `S_IFMT´ undeclared (first use in this function)
qmail-local.c:361: (Each undeclared identifier is reported only once
qmail-local.c:361: for each function it appears in.)
qmail-local.c:361: `S_IFREG´ undeclared (first use in this function)
qmail-local.c: In function `main´:
qmail-local.c:450: warning: return type of `main´ is not `int´
make: ** [qmail-local.o] Erro 1
A hora que chega nessa parte, da o erro e para. Alguem ja se deparou com esse erro? Podem me ajudar a debuga-lo?
