    Padrão cbq não está limitando banda
    olá pessoal ...instalei o cbq mais ele não está limitando banda
    segue mes arquivos e os status
    cbq-0002.teste.in
    DEVICE=eth0,100Mbit,10Mbit
    RATE=10Kbit
    WEIGHT=1Kbit
    PRIO=5
    RULE=192.168.2.10
    BOUNDED=yes
    ISOLATED=yes
    cbq-0002.teste.out
    DEVICE=eth1,100Mbit,10Mbit
    RATE=10Kbit
    WEIGHT=1Kbit
    PRIO=5
    RULE=192.168.2.10,
    BOUNDED=yes
    ISOLATED=yes
    Logs,
    ./cbq compile
    [root@recife init.d]# ./cbq compile
    tc qdisc del dev eth0 root
    tc qdisc add dev eth0 root handle 1 cbq bandwidth 100Mbit avpkt 1000 cell 8
    tc class change dev eth0 root cbq weight 10Mbit allot 1514
    tc qdisc del dev eth1 root
    tc qdisc add dev eth1 root handle 1 cbq bandwidth 100Mbit avpkt 1000 cell 8
    tc class change dev eth1 root cbq weight 10Mbit allot 1514
    tc class add dev eth0 parent 1: classid 1:2 cbq bandwidth 100Mbit rate 10Kbit weight 1Kbit prio 5 allot 1514 cell 8 maxburst 20 avpkt 1000 bounded isolated
    tc qdisc add dev eth0 parent 1:2 handle 2 tbf rate 10Kbit buffer 10Kb/8 limit 15Kb mtu 1500
    tc filter add dev eth0 parent 1:0 protocol ip prio 100 u32 match ip dst 192.168.2.10 classid 1:2
    tc class add dev eth1 parent 1: classid 1:2 cbq bandwidth 100Mbit rate 10Kbit weight 1Kbit prio 5 allot 1514 cell 8 maxburst 20 avpkt 1000 bounded isolated
    tc qdisc add dev eth1 parent 1:2 handle 2 tbf rate 10Kbit buffer 10Kb/8 limit 15Kb mtu 1500
    tc filter add dev eth1 parent 1:0 protocol ip prio 100 u32 match ip src 192.168.2.10 classid 1:2
    log stats
    [root@recife init.d]# ./cbq stats
    ### eth0: queueing disciplines
    qdisc cbq 1: rate 100Mbit (bounded,isolated) prio no-transmit
    Sent 1266 bytes 11 pkts (dropped 0, overlimits 0 requeues 0)
    borrowed 0 overactions 0 avgidle 79 undertime 0
    qdisc tbf 2: parent 1:2 rate 10Kbit burst 10Kb lat 4.0s
    Sent 0 bytes 0 pkts (dropped 0, overlimits 0 requeues 0)
    ### eth0: traffic classes
    class cbq 1: root rate 100Mbit (bounded,isolated) prio no-transmit
    Sent 2466 bytes 19 pkts (dropped 0, overlimits 0 requeues 0)
    borrowed 0 overactions 0 avgidle 81 undertime 0
    class cbq 1:2 parent 1: leaf 2: rate 10Kbit (bounded,isolated) prio 5
    borrowed 0 overactions 0 avgidle 2.32491e+07 undertime 0
    class tbf 2:1 parent 2:
    ### eth0: filtering rules
    filter parent 1: protocol ip pref 100 u32
    filter parent 1: protocol ip pref 100 u32 fh 800: ht divisor 1
    filter parent 1: protocol ip pref 100 u32 fh 800::800 order 2048 key ht 800 bkt 0 flowid 1:2 (rule hit 29 success 0)
    match c0a8020a/ffffffff at 16 (success 0 )
    ### eth1: queueing disciplines
    Sent 113 bytes 2 pkts (dropped 0, overlimits 0 requeues 0)
    ### eth1: traffic classes
    ### eth1: filtering rules
    filter parent 1: protocol ip pref 100 u32 fh 800::800 order 2048 key ht 800 bkt 0 flowid 1:2 (rule hit 2 success 0)
    match c0a8020a/ffffffff at 12 (success 0 )
    ### eth2: queueing disciplines
    qdisc pfifo_fast 0: bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
    Sent 83231442 bytes 112273 pkts (dropped 0, overlimits 0 requeues 0)
    O QUE ESTÁ ERRADO >>> ???????????????????????????????/
    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    cbq-0002.teste.in
    cbq-0002.teste.out
    estao os id estao iguais deixa cbq-0002 e cbq 0003
    o que necessariamente naum ta controlando
    a sua eth0 é a da rede e a eth1 a da internet ???
    se for o up load que naum esta controlando vc tera que fazer a marcação de pacotes para que funcione
    Citação Postado originalmente por Benatto
    cbq-0002.teste.in
    cbq-0002.teste.out
    então seria
    cbq-0002.teste.in
    cbq-0003.teste.out
    a device da rede externa é a ETH1
    e a de rede interna ETH0
    valeu...
    Nov 2002
    Guarapuava-PR
    sim isto ja ajuda
    tenta la
    valeu ....qualquer coisa eu posto o erro...
    blz tá funcionando....
    poŕem tenho algumas duvidas....
    1° no filtro ( RULE )
    eu especifico só o ip. ou tenho que especificar a mascara tambem tanto
    no in como no out ?
    eu posso tabbem limitar uma rede ao inves de Ip,
    ex:
    RULE = 192.168.0.0/24
    valew ...
    Nao limite uma rede inteira, sempre limite por IP ex.: 192.168.0.2/32, ao limitar um range inteiro o cbq bate pino e deixa a rede lenta, conforme voce coloca ips desta range a navegar. :good:
    Experiencia propria :?
    Eu tenho vários clientes que usam várias máquinas,
    não teria uma forma de fazer controle na rede ???
    Outra coisa eu tenho que setar a mascara /32 para cada ip ...?
    falow
    Citação Postado originalmente por rootmaster
    falow
    Voce pode colocar mais de um IP no mesmo arquivo,
    ex.:
    RULE= 192.168.0.2/32
    RULE= 192.168.0.3/32
    RULE= 192.168.0.4/32
    Nunca usei sem mascara, s'o testando!! Mas nao recomendo. :good:
    J'a tentou usar o bandlimit? o cbq 'e muito bom mas 'e complicado e trabalhoso, o bandlimit 'e bem mais simples e funciona direitinho. :?
    Podes me dar uma dica de como funciona o bandlimite,
    instalação ,procedimentos,etc...
    tenho que limitar banda dos meus clientes se meu link vai pro espaço,
    falow
    de uma olhada neste link:
    https://under-linux.org/bandlimit/do...bandlimit-v0.4
    O underlinux tem projeto sobre isto:
    https://under-linux.org/bandlimit.php
    Te uma parte no forum só para isto:
    https://under-linux.org/modules.php?...viewforum&f=22
    :good:
    valeu mano...vou dar uma estudada no script e implementação
    valew a força
    valew a força
    É para isto que estamos ai :clap: :clap: :clap:
