O meu firewall esta dando erro ele nao conecta, quando na politica geral eu coloco drop em input e output ele nao conecta se eu colcar accept ele conecta blz, alguem pode me ajudar?
segue o script:
#!/bin/bash
iniciar () {
# Compartilha a conexao
modprobe ip_nat_ftp
modprobe iptable_nat
IPTABLES=/usr/sbin/iptables
$IPTABLES -t nat -A POSTROUTING -o eth1 -j MASQUERADE
echo "Ativando compartilhamento!"
# Proxy tranparente
$IPTABLES -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
# Politicas de acesso geral
$IPTABLES -P INPUT DROP
$IPTABLES -P OUTPUT ACCEPT
$IPTABLES -P FORWARD DROP
$IPTABLES -I INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
$IPTABLES -I OUTPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
########## loopback #############################################
$IPTABLES -A OUTPUT -p tcp --syn -s 127.0.0.1/255.0.0.0 -j ACCEPT
# localhost
$IPTABLES -A INPUT -i lo -j ACCEPT
$IPTABLES -A OUTPUT -o lo -j ACCEPT
######### Conectividade Social ###################################
INTERNA=eth0 #placa de rede ligada a rede interna
CAIXA=200.201.174.0/24 # IP da Caixa a ser liberado para toda a rede
iptables -t nat -A PREROUTING -i $INTERNA -d 200.201.174.0/24 -j ACCEPT
iptables -t filter -A FORWARD -i $INTERNA -d 200.201.174.0/24 -j ACCEPT
########## Tabelas ################################################
# INPUT ( Pacotes que entra na rede)
$IPTABLES -A INPUT -p tcp -s 10.1.1.0/8 -d 201.76.49.33 --dport 110 -j ACCEPT
$IPTABLES -A INPUT -p tcp -s 10.1.1.0/8 -d 201.76.49.33 --dport 25 -j ACCEPT
$IPTABLES -A INPUT -p tcp --dport 20 -j ACCEPT
# ftp
$IPTABLES -A INPUT -p tcp --dport 21 -j ACCEPT
# smtp
$IPTABLES -A INPUT -p tcp --dport 22 -j ACCEPT
# ssh
$IPTABLES -A INPUT -p tcp --dport 25 -j ACCEPT
# dns
$IPTABLES -A INPUT -p udp --dport 53 -j ACCEPT
# pop3
$IPTABLES -A INPUT -p tcp --dport 110 -j ACCEPT
# http
$IPTABLES -A INPUT -p tcp --dport 80 -j ACCEPT
# HTTPS
$IPTABLES -A INPUT -p tcp --dport 443 -j ACCEPT
$IPTABLES -A INPUT -p tcp --dport 563 -j ACCEPT
# OUTPUT ( Pacotes que sai da rede)
$IPTABLES -A OUTPUT -p tcp -s 10.1.1.0/8 -d 201.76.49.33 --dport 110 -j ACCEPT
$IPTABLES -A OUTPUT -p tcp -s 10.1.1.0/8 -d 201.76.49.33 --dport 25 -j ACCEPT
$IPTABLES -A OUTPUT -p tcp --dport 20 -j ACCEPT
# ftp
$IPTABLES -A OUTPUT -p tcp --dport 21 -j ACCEPT
# smtp
$IPTABLES -A OUTPUT -p tcp --dport 25 -j ACCEPT
# ssh
# dns
$IPTABLES -A OUTPUT -p udp --dport 53 -j ACCEPT
# pop3
$IPTABLES -A OUTPUT -p tcp --dport 110 -j ACCEPT
# httpd
$IPTABLES -A OUTPUT -p tcp --dport 80 -j ACCEPT
# HTTPS
$IPTABLES -A OUTPUT -p tcp --dport 443 -j ACCEPT
$IPTABLES -A OUTPUT -p tcp --dport 563 -j ACCEPT
# FORWARD - REDE LOCAL
$IPTABLES -A FORWARD -p tcp --dport 20 -j ACCEPT
# ftp
$IPTABLES -A FORWARD -p tcp --dport 21 -j ACCEPT
# SSH
$IPTABLES -A FORWARD -p tcp --dport 22 -j ACCEPT
# smtp
$IPTABLES -A FORWARD -p tcp --dport 25 -j ACCEPT
# SMTP
$IPTABLES -A FORWARD -p tcp --sport 25 -j ACCEPT
# dns
$IPTABLES -A FORWARD -p udp --dport 53 -j ACCEPT
# pop3
$IPTABLES -A FORWARD -p tcp --dport 110 -j ACCEPT
# pop3
$IPTABLES -A FORWARD -p tcp --sport 110 -j ACCEPT
# POP
$IPTABLES -A FORWARD -p tcp --dport 8333 -j ACCEPT
# HTTPS
$IPTABLES -A FORWARD -p tcp --dport 443 -j ACCEPT
$IPTABLES -A FORWARD -p tcp --dport 563 -j ACCEPT
# msn
$IPTABLES -A FORWARD -s 10.1.1.0/8 -p tcp --dport 1863 -j REJECT
$IPTABLES -A FORWARD -s 10.1.1.0/8 -j ACCEPT
echo "Firewall Ativado"
parar(){
iptables -F
iptables -t nat -F
echo "Regras de firewall e compartilhamento desativados"
case "$1" in
"start") iniciar ;;
"stop") parar ;;
"restart") parar; iniciar ;;
*) echo "Use os parametros start ou stop"
esac
