- Bug no setup do samba
Pessoal apos remover o pacote com dpkg -r samba e apagar o diretorio no /etc, fui instalar denovo o samba porem da a seguinte mensagem, oque posso fazer para instalar ele denovo ? Grato.
bells:/# apt-get install samba
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
smbldap-tools ldb-tools
The following NEW packages will be installed:
samba
0 upgraded, 1 newly installed, 0 to remove and 465 not upgraded.
Need to get 0B/4292kB of archives.
After this operation, 11.7MB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously deselected package samba.
(Reading database ... 57210 files and directories currently installed.)
Unpacking samba (from .../samba_2%3a3.2.3-3_i386.deb) ...
Processing triggers for man-db ...
Setting up samba (2:3.2.3-3) ...
Starting Samba daemons: nmbd failed!
invoke-rc.d: initscript samba, action "start" failed.
dpkg: error processing samba (--configure):
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
samba
E: Sub-process /usr/bin/dpkg returned an error code (1)
Baixar pacote do site especificado Samba -- Opening Windows to a Wider World
Descompacta-lo com o comando tar -xzvf samba-3.0.14a.tar.gz (verificar a versão atual)
Entrar no diretório samba-3.0.14a/source
Executar o comando ./configure --prefix=/usr --sysconfdir=/etc/samba --localstatedir=/var --with-configdir=/etc/samba --with-privatedir=/etc/samba --with-acl-support --with-profile --with-smbmount
Executar o comando make
Executar o comando make install
Entrar no diretório samba-3.0.14a/packaging/Fedora
Editar o arquivo samba.xinetd e mudar o parâmetro disable de yes para no e comentar a linha only_from
Copiar o arquivo samba.xinetd para /etc/xinetd.d com o nome de swat (cp samba.xinetd /etc/xinetd.d/swat) e depois reiniciar o serviço xinetd (/etc/rc.d/init.d/xinetd restart)
Copiar o arquivo smb.conf para o diretório /etc/samba (cp smb.conf /etc/samba)
Mudar a permissão do arquivo smb.init e copia-lo para o diretório /etc/rc.d/init.d com o nome de samba (ou smb) e digitar o comando chkconfig --add samba (ou smb)
depois disso vc pode configurar o seu samba da sua forma !!!!
