mas não há erros.
Slackware 12.1, squid transparente.
o squid aqui estava funcionando há mais ou menos um mês sem problemas. De um momento para outro, simplesmente não opera mais, ou seja, não atende as requisições de acesso às paginas http.
O access.log não está registrando mais nada, está mesmo congeladão. O que já fiz:
squid ESTÁ "escutando" na porta 3128
removi o access.log e o recriei
removi o cache e o recriei (squid -z)
squid -d 255 NÃO MOSTRA ERRO:
2008/11/06 13:53:48| Starting Squid Cache version 3.0.STABLE9 for i486-slackware-linux-gnu...
2008/11/06 13:53:48| Process ID 2995
2008/11/06 13:53:48| With 1024 file descriptors available
2008/11/06 13:53:48| Performing DNS Tests...
2008/11/06 13:53:49| Successful DNS name lookup tests...
2008/11/06 13:53:49| DNS Socket created at 0.0.0.0, port 48771, FD 7
2008/11/06 13:53:49| Adding domain carv.com.br from /etc/resolv.conf
2008/11/06 13:53:49| Adding nameserver 127.0.0.1 from /etc/resolv.conf
2008/11/06 13:53:49| Adding nameserver 208.67.222.222 from /etc/resolv.conf
2008/11/06 13:53:49| Adding nameserver 208.67.220.220 from /etc/resolv.conf
2008/11/06 13:53:49| Unlinkd pipe opened on FD 12
2008/11/06 13:53:49| Swap maxSize 524288 KB, estimated 40329 objects
2008/11/06 13:53:49| Target number of buckets: 2016
2008/11/06 13:53:49| Using 8192 Store buckets
2008/11/06 13:53:49| Max Mem size: 262144 KB
2008/11/06 13:53:49| Max Swap size: 524288 KB
2008/11/06 13:53:49| Version 1 of swap file with LFS support detected...
2008/11/06 13:53:49| Rebuilding storage in /var/spool/squid (DIRTY)
2008/11/06 13:53:49| Using Least Load store dir selection
2008/11/06 13:53:49| Set Current Directory to /var/spool/squid
2008/11/06 13:53:49| Loaded Icons.
2008/11/06 13:53:49| Accepting transparently proxied HTTP connections at 128.0.11.5, port 3128, FD 14.
2008/11/06 13:53:49| HTCP Disabled.
2008/11/06 13:53:49| Ready to serve requests.
2008/11/06 13:53:49| Done reading /var/spool/squid swaplog (0 entries)
2008/11/06 13:53:49| Finished rebuilding storage from disk.
2008/11/06 13:53:49| 0 Entries scanned
2008/11/06 13:53:49| 0 Invalid entries.
2008/11/06 13:53:49| 0 With invalid flags.
2008/11/06 13:53:49| 0 Objects loaded.
2008/11/06 13:53:49| 0 Objects expired.
2008/11/06 13:53:49| 0 Objects cancelled.
2008/11/06 13:53:49| 0 Duplicate URLs purged.
2008/11/06 13:53:49| 0 Swapfile clashes avoided.
2008/11/06 13:53:49| Took 0.02 seconds ( 0.00 objects/sec).
2008/11/06 13:53:49| Beginning Validation Procedure
2008/11/06 13:53:49| Completed Validation Procedure
2008/11/06 13:53:49| Validated 25 Entries
2008/11/06 13:53:49| store_swap_size = 0
2008/11/06 13:53:50| storeLateRelease: released 0 objects
removi e (re)instalei o squid; continua sem funcionar.
Que faço agora, chamo um pai-de-santo?
por favor, eu tive que permitir livre transito da galera para a internet mas o patrão NÃO VAI ficar feliz com isso. Nem eu.
TIA.
  Citação
 pra facilitar a vida. Mas tem quem goste de sofrer e deixe OPEN só pra ficar criando trilhões de regras proibindo isso e aquilo
