Pessoal internet passa o dia ok e tem horas que fica muito lenta..temos um link dedicado de 1mb dividido em 512k para internet e 512k para voip com HTB+tc e funciona bem..mas agora mesmo testando a internet estava dando 190kpbs no velocimetro então parei o proxy, e iniciei novamente e voltou ao normal dando 495kpbs a 500kpbs então coloquei meu squid.conf abaixo para vcs me darem uma ajuda;:
NOME DO SERVIDOR#####################################################
visible_hostname DebianLinux
#IP+PORTA USADA ####################################################
http_port 10.0.1.254:3128
icp_port 0
#CACHE USADO-METADE DA RAM)###########################################
cache_mem 256 MB
#Cache Swap###########################################################
cache_swap_low 80
cache_swap_high 90
#OBJECT_SIZE##########################################################
maximum_object_size 512 MB
minimum_object_size 0 KB
#tamanho m?ximo dos objetos alocados na mem?ria.
maximum_object_size_in_memory 256 KB
#DIRETORIOS DO CACHE MULTIPLOS########################################
cache_dir aufs /var/cachesquid1 5000 128 512
#cache_dir aufs /var/cachesquid2 2900 128 512
#cache_dir aufs /var/cachesquid3 2900 128 512
#cache_dir aufs /var/cachesquid4 2900 128 512
#cache_dir aufs /var/cachesquid5 2900 128 512
# Resolve um problema com conex?es persistentes que ocorre com certos servidores,
# e que provoca delays em nosso cache.
detect_broken_pconn on
# Provoca um ganho de performance ao usar conex?es Pipeline (requisi??es em
# paralelo)
pipeline_prefetch on
#DNS squid cache
dns_nameservers 10.0.1.254
#LOGS################################################################
cache_log /var/log/squid/cache.log
cache_store_log none
#REGRA AUTENTICACAO
auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/passwd
auth_param basic children 3
authenticate_ttl 10 minutes
authenticate_ip_ttl 0
request_body_max_size 0 MB
#ACL's########################################################
#SITES QUE N?O PRECISAM DE AUTENTICACAO COM SENHA
acl NO_AUTH url_regex -i '/etc/squid/no_auth_url'
http_access allow NO_AUTH
#SITES BLOQUEADOS PARA QUALQUER USUARIO
#acl BLOCK url_regex -i '/etc/squid/bloqueados'
#http_access deny BLOCK
#MSN S? PARA USUARIOS DESSA ACL##################
acl bloqueiamsn url_regex -i "/etc/squid/bloqueiamsn"
acl g_liberado proxy_auth alisson roze neide ademario wpsc luiz.roma marinalvaxp natasha fernando rmartins vicente inspetor diego handerson
http_access deny bloqueiamsn !g_liberado
##### BLOQUEIO DE DOWNLOAD DAS EXTENSOES ABAIXO##
acl EXTENSOES url_regex -i \.arj \.mp3 \.bat \.pif \.scr \.src \.wma \.avi \.wmv \.pps \.ppt
http_access deny EXTENSOES
#REGRAS GERAIS###################################
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 4243 563
acl Safe_ports port 80 21 443 563 70 210 1025-65535
acl CONNECT method CONNECT
http_access deny manager
http_access deny !Safe_ports
http_access allow localhost
#CACHE FULL
#refresh_pattern (/cgi-bin/|\?) 0 0% 0
#refresh_pattern . 0 20% 4
#adicionado para testes
#refresh_pattern ^ftp: 15 20% 2280
#refresh_pattern ^gopher: 15 0% 2280
#refresh_pattern . 15 20% 2280
#FTP
ftp_passive on
ftp_sanitycheck on
#Estas 'refresh_pattern' fazem com que o squid mantenha o maximo
#possivel um objeto em cache, aumentando o cache HIT e byte HIT
refresh_pattern -i \.jpg$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.gif$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.png$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.jpeg$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.bmp$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.tif$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.tiff$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.swf$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.exe$ 0 50% 21600 reload-into-ims
refresh_pattern -i \.php$ 0 20% 1440 reload-into-ims
refresh_pattern -i \.html$ 0 20% 1440 reload-into-ims
refresh_pattern -i \.htm$ 0 20% 1440 reload-into-ims
refresh_pattern -i \.shtml$ 0 20% 1440 reload-into-ims
refresh_pattern -i \.shtm$ 0 20% 1440 reload-into-ims
refresh_pattern . 0 20% 4320
meu squid é autenticado e só é liberado o que eu quero então não pode ser abuso do link...se só em momentos ai que não é mesmo.Minha maquina é um P4 2.66ghz/160GB de HD/1GB de memoria ram
rodo o bind + apache + sarg + squid + htb + firewall nessa máquina a um ano e nunca tive problemas...eu reiniciei ela segunda e hoje já aconteceu isso novamente queria ajuda pois sempre trabalhei normalmente com 512k de link para 20 usuários e muitos deles só tem acesso a outlook.
Citação
