Olá todos!
Estou tendo um problema para autenticar mac da wireless mikrotik no freeradius 2 no "1.171 era tranquilo"
uso debian 5.5 lenny postgres e php consigo autenticar hotspot,pppoe,dchp,winbox,ssh etc... mas mac wirelless ta dificil
ja tentei parametros : "User-Passord" da isso no log
Sat Aug 14 00:55:02 2010 : Auth: Login incorrect: [00:05:9E:8B:11:35/00:05:9E:8B:11:35] (from client SERVIDOR port 0 cli 00-05-9E-8B-11-35)
attribute "Password"
Sat Aug 14 00:56:09 2010 : Auth: Login incorrect (rlm_pap: empty password supplied): [00:05:9E:89:4B:09/] (from client SERVIDOR port 0 cli 00-05-9E-89-4B-09)
attribute "Cleartext-Password"
Sat Aug 14 00:56:10 2010 : Auth: Login incorrect: [00:05:9E:83:BBA/] (from client SERVIDOR port 0 cli 00-05-9E-83-BB-DA)
Gostaria de saber se alguem ja teve este problema e poderia me dar uma luz pois virei a net umas 10 vezes e não acho solução.
Abaixo um debug do meu freeradius
Obrigado a todos pela atenção!
Going to the next request
Ready to process requests.
rad_recv: Access-Request packet from host 187.28.xxx.xx port 58645, id=15, length=155
Service-Type = Framed-User
NAS-Port-Id = "wlan1"
User-Name = "00:15:6D0:70:1D"
Calling-Station-Id = "00-15-6D-D0-70-1D"
Called-Station-Id = "00-0B-6B-DC-1D-5E:BINHO58"
User-Password = ""
NAS-Identifier = "SERVIDOR_VIRTUAL_MIKROTIK_BINHO"
NAS-IP-Address = 187.28.xxx.xx
+- entering group authorize
rlm_pap: WARNING! No "known good" password found for the user. Authentication may fail because of this.
++[pap] returns noop
++[preprocess] returns ok
++[chap] returns noop
++[mschap] returns noop
rlm_realm: No '@' in User-Name = "00:15:6D0:70:1D", looking up realm NULL
rlm_realm: No such realm "NULL"
++[suffix] returns noop
rlm_eap: No EAP-Message, not doing EAP
++[eap] returns noop
++[unix] returns notfound
++[files] returns noop
expand: %{User-Name} -> 00:15:6D0:70:1D
rlm_sql (sql): sql_set_user escaped user --> '00:15:6D0:70:1D'
rlm_sql (sql): Reserving sql socket id: 4
expand: SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = '00:15:6D0:70:1D' ORDER BY id
rlm_sql_postgresql: query: SELECT id, UserName, Attribute, Value, Op FROM radcheck WHERE Username = '00:15:6D0:70:1D' ORDER BY id
rlm_sql_postgresql: Status: PGRES_TUPLES_OK
rlm_sql_postgresql: query affected rows = 1 , fields = 5
expand: SELECT GroupName FROM usergroup WHERE UserName='%{SQL-User-Name}' ORDER BY priority -> SELECT GroupName FROM usergroup WHERE UserName='00:15:6D0:70:1D' ORDER BY priority
rlm_sql_postgresql: query: SELECT GroupName FROM usergroup WHERE UserName='00:15:6D0:70:1D' ORDER BY priority
rlm_sql_postgresql: query affected rows = 0 , fields = 1
rlm_sql (sql): Released sql socket id: 4
rlm_sql (sql): User 00:15:6D0:70:1D not found
++[sql] returns notfound
++[expiration] returns noop
++[logintime] returns noop
auth: No authenticate method (Auth-Type) configuration found for the request: Rejecting the user
auth: Failed to validate the user.
Login incorrect: [00:15:6D0:70:1D/] (from client SERVIDOR_VIRTUAL_MIKROTIK_BINHO port 0 cli 00-15-6D-D0-70-1D)
Found Post-Auth-Type Reject
+- entering group REJECT
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] returns updated
Delaying reject of request 14 for 1 seconds
Citação
