    Question Openvpn +Bridge
    Bom dia,
    Estou tentando configura o openvpn no modo bridge e nao estou obtendo sucesso, solicito uma luz dos amigo onde posso esta errando. estou conseguindo me conectar a minha vpn, mais nao consigo pingar nenhuma maquia da rede 10.1.8.0/21.
    OS: Centos 5.5
    Kernel: 2.6.18
    OpenVPN: 2.1.4
    Rede: 10.1.8.0/21
    Configuracao rede linux:
    [root@openvpn openvpn]# ifconfig eth0
    eth0 Link encap:Ethernet Endereço de HW 00:0F:EA:B4:11:FC
    endereço inet6: fe80::20f:eaff:feb4:11fc/64 Escopo:Link
    UP BROADCASTRUNNING PROMISC MULTICAST MTU:1500 Métrica:1
    RX packets:15462 errors:0 dropped:0 overruns:0 frame:0
    TX packets:4264 errors:0 dropped:0 overruns:0 carrier:0
    colisões:0 txqueuelen:1000
    RX bytes:1565400 (1.4 MiB) TX bytes:489118 (477.6 KiB)
    IRQ:185 Endereço de E/S:0xa800
    Configuracao OpenVPN:
    # /etc/openvpn/server.conf
    proto udp
    port 22223
    dev tap0
    server-bridge 10.1.8.6 255.255.248.0 10.1.15.200 10.1.15.253
    comp-lzo
    keepalive 10 120
    persist-key
    persist-tun
    float
    ifconfig-pool-persist /etc/openvpn/ipp.txt
    max-clients 10
    push shaper 512
    tls-server
    log-append /var/log/openvpn.log
    status /var/log/openvpn-status.log
    ca keys/ca.crt
    cert keys/server.crt
    key keys/server.key
    dh keys/dh1024.pem
    tls-auth keys/static.key
    # crl-verify keys/crl.pem
    Configuracao cliente:
    # C:\Arquivos de programas\OpenVPN\config
    remote 10.1.8.6
    #remote vpn.ers.com
    #remote-random
    remote-cert-tls server
    proto udp
    port 22223
    client
    pull
    dev tap
    comp-lzo
    keepalive 10 120
    persist-key
    persist-tun
    float
    tls-client
    dh keys/dh1024.pem
    ca keys/ca.crt
    cert keys/eghijs.crt
    key keys/eghijs.key
    Scripts bridge:
    #!/bin/bash
    # /etc/openvpn/bridge-start
    br="br0"
    tap="tap0"
    eth="eth0"
    eth_ip="10.1.8.6"
    eth_gw="10.1.8.254"
    eth_netmask="255.255.248.0"
    eth_broadcast="10.1.15.255"
    for t in $tap; do
    openvpn --mktun --dev $t
    done
    brctl addbr $br
    brctl addif $br $eth
    for t in $tap; do
    brctl addif $br $t
    done
    for t in $tap; do
    ifconfig $t 0.0.0.0 promisc up
    done
    ifconfig $eth 0.0.0.0 promisc up
    ifconfig $br $eth_ip netmask $eth_netmask broadcast $eth_broadcast
    route add defalt gw $eth_gw dev $br
    #!/bin/bash
    br="br0"
    tap="tap0"
    ifconfig $br down
    brctl delbr $br
    for t in $tap; do
    openvpn --rmtun --dev $t
    done
    Iniciando o servico:
    [root@openvpn openvpn]# ./bridge-start
    Mon Mar 14 04:44:17 2011 TUN/TAP device tap0 opened
    Mon Mar 14 04:44:17 2011 Persist state set to: ON
    defalt: Falha na procura do nome de host
    [root@openvpn openvpn]# service openvpn start
    Iniciando openvpn: (OK)
    Tabela de rota do windows:
    ver anexo
    Configuracao da rede windows apos conexao vpn:
    ver anexo
    Grato,
Nome:	         Win_vpn_rede_config.JPG
Visualizações:	124
Tamanho: 	63,3 KB
ID:      	20501   Clique na imagem para uma versão maior
Nome:	         route_win.JPG
Visualizações:	120
Tamanho: 	83,2 KB
Nome:	         client_windows.jpg
Visualizações:	130
Tamanho: 	81,4 KB
