What's new in 5.9 (2011-Nov-29 14:32):
*) wireless - nv2 improvements for 11n cards;
*) wireless - change default rate-selection to advanced;
*) ssh - fix memory leak when client uses public key authentication;
*) ppp - added support for new RADIUS attribute MT-Delegated-IPv6-Pool (#22);
*) ntp client - faster initial synchronization;
*) ppp - added support for dhcpv6 pd;
*) hotspot - fixed login page to better handle big load;
*) snmp - fix simple queue table;
*) webfig - fixed problem were users wihtout sensitive permission could download
senstive files (like backups);
*) webfig - fixed problem were table filters did not work allways as expected;
*) metarouter - fixed problem where local routeros instances did not boot;
*) dhcpv6 - client and server moved to respective /ipv6 dhcp- entry;
*) dhcpv6 server - changed how bindings are defined, users should add
missing static binding information after upgrade;
*) sms - send sms now uses channel from config if it's not specified in the command;
http://www.mikrotik.com/download.html
Muitos provedores ainda usam versão pirata será que realmente vale apena? AMIGO "passou" esta na hora de MUDAR
  Citação
