    Cool Cache Full na Versão 3.30 Usando PPPoE
    Olá Pessoal!
    Alguém sabe me dizer se há alguma coisa que devo implementar para fazer o CACHE FULL na versão 3.30, sendo que uso autenticação por PPPoE.
    Apliquei as regras direto da WIKI do Mikrotik: Queue with Masquerading and Internal Web-Proxy
    Minhas regras estão iguais ao da WIKI (mudando apenas a classe de IPs)
    Código PHP:
    ip firewall nat print
    Flagsdisabledinvaliddynamic
     0
    ;;; Firewall NAT
         chain
    =srcnat action=masquerade src-address=192.168.4.0/24 out-interface=public
    1   chain=dstnat action=redirect to-ports=3128 protocol=tcp src-address=192.168.4.0/24 in-interface=local dst-port=80
    Código PHP:
    ip firewall mangle print
     0
    ;;; HIT TRAFFIC FROM PROXY
         chain
    =output action=mark-packet new-packet-mark=proxy-hit passthrough=no out-interface=local dscp=
    ;;; UP TRAFFIC
         chain
    =prerouting action=mark-packet new-packet-mark=test-up passthrough=no src-address=192.168.4.0/24 in-interface=local
     2
    ;;; CONN-MARK
         chain
    =forward action=mark-connection new-connection-mark=test-conn passthrough=yes src-address=192.168.4.0/24
     3
    ;;; DOWN-DIRECT CONNECTION
         chain
    =forward action=mark-packet new-packet-mark=test-down passthrough=no in-interface=public connection-mark=test-conn
     4
    ;;; DOWN-VIA PROXY
         chain
    =output action=mark-packet new-packet-mark=test-down passthrough=no dst-address=192.168.4.0/24 out-interface=local
    Código PHP:
    queue tree print
     0   name
    ="downstream" parent=local packet-mark=test-down limit-at=100M queue=default priority=8 max-limit=100M burst-limit=
         burst
    -threshold=0 burst-time=0s
     1   name
    ="upstream" parent=global-in packet-mark=test-up limit-at=100M queue=default priority=8 max-limit=100M burst-limit=
         burst
    Código PHP:
    ip proxy print
    enabledyes
                 src
    -address0.0.0.0
                        port
    3128
                parent
    -proxy0.0.0.0
           parent
    -proxy-port0
         cache
    -administrator"webmaster"
    max-cache-sizenone
               cache
    -on-diskyes
      max
    -client-connections600
      max
    -server-connections600
              max
    -fresh-time3d
       serialize
    -connectionsno
           always
    -from-cacheno
              cache
    -hit-dscp4
                 cache
    -drivesata1
Nome:	         proxy.PNG
Visualizações:	743
Tamanho: 	21,0 KB
    Alguém pode me dizer o que poderia ser?
    Padrão re: Cache Full na Versão 3.30 Usando PPPoE
    ninguém ?
    pessoal, quem conseguiu, basta postar as regras do firewall nat, mangle, web-proxy e queue que eu já me viro só!
    pois as regras que eu encontrei aqui no forum não estão funcionando!
    Lembrando que para a versão 2.9.x eu consegui legal! Funcionou perfeito, só não estou conseguindo na versão 3.x.
    obrigado!
    Estava usando estas regras aqui com cache no próprio MK, não é em paralelo:
    add action=mark-connection chain=output comment="PROXY FULL" disabled=no new-connection-mark=proxyfull passthrough=yes protocol=tcp src-port=5128
    add action=mark-packet chain=output comment="" connection-mark=proxyfull disabled=no new-packet-mark=proxyfull passthrough=yes
    add action=return chain=output comment="" connection-mark=proxyfull disabled=no
    Ivan Galves
    Consegui pessoal!!
    /ip firewall nat
    add action=masquerade chain=srcnat comment=nat disabled=no \
    out-interface=public src-address=192.168.4.0/24
    add action=redirect chain=dstnat comment="redirect port 80 to 3128" \
    disabled=no dst-port=80 protocol=tcp src-address=192.168.4.0/24 \
    to-ports=3128
    /ip firewall mangle
    add action=mark-connection chain=output comment=\
    "mark connection *conn_squid-up*" content="X-Cache: HIT" disabled=\
    no new-connection-mark=conn_squid-up passthrough=yes protocol=tcp \
    src-port=3128
    add action=mark-packet chain=output comment=\
    "mark packet *pacotes_squid-up*" connection-mark=conn_squid-up \
    disabled=no new-packet-mark=pacotes_squid-up passthrough=yes
    add action=mark-connection chain=prerouting comment=\
    "mark connection *conn_squid-down*" disabled=no dst-port=3128 \
    new-connection-mark=conn_squid-down passthrough=yes protocol=tcp
    add action=mark-packet chain=prerouting comment=\
    "mark packet *pacotes_squid-down*" connection-mark=conn_squid-down \
    disabled=no new-packet-mark=pacotes_squid-down passthrough=yes
    /ip firewall filter
    add action=drop chain=input comment="block external proxy" disabled=no \
    dst-port=3128 in-interface=public protocol=tcp
    add action=accept chain=input comment="accept connections from proxy" \
    disabled=no dst-port=3128 protocol=tcp
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=\
    0 max-limit=150M name=downstream packet-mark=pacotes_squid-down \
    parent=global-in priority=1 queue=default
    0 max-limit=150M name=upstream packet-mark=pacotes_squid-up parent=\
    global-out priority=1 queue=default
    /ip proxy
    set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=yes enabled=yes max-cache-size=408555000KiB \
    max-client-connections=600 max-fresh-time=3d \
    max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 \
    port=3128 serialize-connections=no src-address=0.0.0.0
    /ip proxy access
    add action=deny comment="block telnet & spam e-mail relaying" disabled=\
    no dst-port=23-25
    add action=allow comment=web-proxy disabled=no src-address=\
    192.168.4.0/24
    add action=deny comment=web-proxy disabled=no
    Não existe cache full. Isso é lenda. O nome é "misleading".
    Não entendi, pode até existir diferentes nomes, mas todos sabendo o que é.
    Mas o "FULL" da cache, para mim, não está relacionado a "guardar" tudo, e sim, "tudo" quer for quardado enviar na velocidade FULL que a rede do provedor/lan suportar.
    Para mim, é isso. Mas entendi sua opnião, isso realmente acontece.
    Avatar de Aredeprovedor
    Jan 2009
    Pôrto Das Caixas, Rio De Janeiro, Brazil, Brazil
    Citação Postado originalmente por BraZuky Ver Post
    Consegui pessoal!!
    Caros amigos,
    Essa regra que o amigo postou funciona bem onde o cache é no cartão de memoria que está no mikrotik e onde minhas portas estão todas ligadas por uma bridge??? essa interface public seria a interface da rede dos cliente, correto?
    Pelo que eu entendi so precisaria mudar o ip da minha rede e o nome das portas.
    Citação Postado originalmente por Aredeprovedor Ver Post
    Caros amigos,
    Isso amigo.
    Consegui pessoal!!
    Fala amigão, blz?... achei seu post interessante, so tenho 1 duvida que acho que foi a sua tb, olha só, meu MK (Placa Clientes tem o IP 10.1.1.1/24 - e se eu copiar esse seu codigo eu iria apenas mudar os ips do seu para o meu?...aguardo ansioso... valeu!)... Uso Hotspot com IP fixo nos clientes...e não PPPoe.. Valeu!..,
    Última edição por simplification; 04-09-2010 às 23:14.
    isso mesmo amigo....mude a faixa de ip de acordo com a sua rede
    Jan 2009
    Olá,
    Coloquei em uso o script acima mas não funcionou legal, alguns cliente ficaram com a conexão lenta e alguns sites estavam abrindo paginas antigas como a da globo.com, se eu não me engano eu vi algum comentário informando um script que colocava sites como da globo.com como exeção.
    Será que a lentidão é pq eu uso um microSD na placa? e alguém saberia informa qual é esse script?
    E eu acho que o cache esta sendo guardado na memoria da placa não do cartão!!
    esse ip que ta na sua config é o ip do pppoe server (Clientes) ou da rede normal?
    pergunto pq aqui uso 172.xxx.xxx.xxx para dhcp-server e 192.xxx.xxx.xxx para cliente pppoe...
    Padrão Re: Cache Full na Versão 3.30 Usando PPPoE (RESOLVIDO)
    tive que mudar a resposta pois ha um erro no seu código:
    /ip firewall nat
    add action=masquerade chain=srcnat comment=nat disabled=no out-interface=\
    public src-address=xxx.xxx.xxx.0/24
    mudei de public para pppoe-out1 e funcionou todos sites inclusive https:// ...
    Citação Postado originalmente por darkorion Ver Post
    mudei umas coisinhas até conseguir, para quem quiser testar, siga a legenda no final, esta explicadinho aqui:
    (ja alterado para o que funcionou aqui)
    /ip firewall nat
    pppoe-out1 src-address=xxx.xxx.xxx.0/24
    add action=redirect chain=dstnat comment="redirect port 80 to 3128" disabled=\
    no dst-port=80 protocol=tcp src-address=xxx.xxx.xxx.0/24 to-ports=3128
    /ip firewall mangle
    "mark connection *conn_squid-up*" content="X-Cache: HIT" disabled=no \
    new-connection-mark=conn_squid-up passthrough=yes protocol=tcp src-port=\
    3128
    add action=mark-packet chain=output comment="mark packet *pacotes_squid-up*" \
    connection-mark=conn_squid-up disabled=no new-packet-mark=\
    /ip firewall filter
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
    max-limit=150M name=downstream packet-mark=pacotes_squid-down parent=\
    /ip proxy
    cache-on-disk=yes enabled=yes max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=0.0.0.0 parent-proxy-port=0 port=3128 serialize-connections=\
    /ip proxy access
    add action=deny comment="block telnet & spam e-mail relaying" disabled=no \
    dst-port=23-25
    add action=allow comment=web-proxy disabled=no src-address=xxx.xxx.xxx.0/24
    LEGENDA:
    network > interface onde estão os clientes pppoe
    xxx.xxx.xxx.0/24 > faixa de ip dos clientes pppoe (não da rede local e sim do pppoe server)
    unlimited > espaço que podera ser ocupado no disco com o cache (hd80gb deixe unlimited ou 75000000 para 75gb por exemplo)
    pppoe-out1 > pppoe-client (quando modem em bridge)
    ja vi varios posts aqui no under porem não funcionaram não sei pq, hoje testei este do zero como sempre e funcionou 90% com cache full, só não deu 100% pq não esta abrindo paginas do hotmail e nem https: ...não sei pq... se alguem souber ajude-nos... plz...
    como este post não é meu peço ao amigo BraZuKy que copie minha resposta e modifique seu post, pois os códigos postados aqui foi ele quem postou... eu apenas legendei o mesmo...
    Última edição por darkorion; 10-01-2012 às 13:33.
    Avatar de ShiFT
    Sep 2010
    Francisco Beltrão - PR
    Acompanhando o tópico, tenho estrutura seguinte. ModemRoteado->EtherInternet(10.10.10.2)-EtherCliente(192.168.251.0/24)
    Pessoal boa noite, sou iniciante, estou tentando fazer um cache full com mikrotik versão 2.9.27 level 6 , mas não estou conseguindo sera que alguem poderia me ajudar...
    Obrigado
    Lucas,
    Citação Postado originalmente por labme Ver Post
    Obrigado
    Lucas,
    Volte para o começo e leia muito, pesquise aqui no fórum e em outros, pq assim vc está fazendo tudo errado.
    Amigo, ja uso ele a algum tempo, mas onde tenho provedor estamos com link um pouco limitado, o basico eu faço, mas agora surgiu esta ideia ja pesquisei em varios lugar, fiz varios códigos sera que podem me ajudar ?
    Quanto de link vc tem? Quantos clientes? E cache no mikrotik pode esquecer, não rola.
    Se tiver mais de 10 clientes já passou a hora de trocar esse pc com mikrotik crackeado por uma Rb 450g pelo menos, já que vc espera crescer e colocar mais clientes em sua rede.
