-  Snmp e mrtg
 Snmp e mrtg
							Pessoal estou tentando configurar o SNMTP no Debian Squeeze e nao estou conseguindo, aparece o erro:
root@gw:~# /etc/init.d/snmpd status
snmpd is running.
snmptrapd is not running ... failed!
Ai quando executo o comando do MRTG:
root@gw:~# cfgmaker "teste"@127.0.0.1 > /etc/mrtg.cfg
SNMP Error:
no response received
SNMPv1_Session (remote host: "127.0.0.1" [127.0.0.1].161)
community: "teste"
request ID: -1812739261
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/share/perl5/SNMP_util.pm line 629
SNMPWALK Problem for 1.3.6.1.2.1.1 on [email protected]::::::v4only
at /usr/bin/cfgmaker line 961
WARNING: Skipping [email protected]: as no info could be retrieved
Alguém ja viu esse problema?
Existe algum manual para a instalação do SNMP e MRTG para Debian 6 Squeeze?
Obrigado
Leandro Dutra
 Re: Snmp e mrtg
							Pessoal consegui resolver.
Configurando o SNMPD.conf
#vim /etc/snmp/snmpd.conf
agentAddress udp:161,udp6:[::1]:161
view systemonly included .1.3.6.1.2.1.1
view systemonly included .1.3.6.1.2.1.25.1
rocommunity public localhost
Sair salvando e reinicia o serviço:
#/etc/init.d/snmpd restart
MRTG
#cfgmaker "public"@127.0.0.1 > /etc/mrtg.cfg
Editar o arquivo mrtg.cfg se estiver com erro
MaxBytes[127.0.0.1_2]: 0
Troque pela linha
MaxBytes[127.0.0.1_2]: 1250000
Agora adicione a linha:
Options[127.0.0.1_2]: bits
E execute o comando:
#indexmaker /etc/mrtg.cfg > /var/www/mrtg/index.html
Pronto agora aguarde 5 minutos.
Obrigado
