info: reading config file [/usr/local/etc/msn-proxy/msn-proxy.conf]
SQL: (SHOW TABLES)
SQL: (SELECT connect, save_msg, save_contacts, commands, internal_host FROM defaults LIMIT 1)
msn-proxy release     : msn-proxy-0.7a [$Id: msn-proxy.h 112 2009-03-15 17:30:28Z loos-br $]
config file           : /usr/local/etc/msn-proxy/msn-proxy.conf
default ns host       : messenger.hotmail.com
default ns port       : 1863
listen host           : 0.0.0.0
listen port           : 1863
backlog               : 10
max clients           : 50
max ctl clients       : 10
port range begin      : 25000
port range end        : 30000
ctl read timeout      : 5
client read timeout   : 600
client write timeout  : 60
server read timeout   : 600
server write timeout  : 60
client connect timeout: 180
ACLs
connect               : ALLOW
log messages          : YES
save_contacts         : YES
listen on [0.0.0.0:1863]
SQL: (DELETE FROM sb)
SQL: (UPDATE contacts SET contact_status = 'OFF', contact_deny = contact_deny & ~4194304)
SQL: (UPDATE users SET status = 'OFF')
debug: connection from [192.168.0.167]
connected to [messenger.hotmail.com:1863]
debug: ns client pre command not accepted
VER 1 MSNP21 MSNP20 MSNP19 MSNP18 MSNP17 CVR0
payload: [(null)]
payload: [(null)]
payload: [(null)]
