Vi no site da MIKROTIK que estão utilizando o protocolo TDMA, que se chama NV2, segue link do site da MIKRoTIK:
Manual:Interface/Wireless - MikroTik Wiki
Está bem no meio da página.
Nv2
MikroTik has developed a new wireless protocol based on TDMA technology (Time Division Multiple Access) - Nv2 (Nstreme version 2).
TDMA is a channel access method for shared medium networks. It allows several users to share the same frequency channel by dividing the signal into different time slots. The users transmit in rapid succession, one after the other, each using his own time slot. This allows multiple stations to share the same transmission medium (e.g. radio frequency channel) while using only a part of its channel capacity.
The most important benefits of Nv2 are:
Increased speed
More client connections in PTM environments
Lower latency
No distance limitations
No penalty for long distances
Starting from RouterOS v5.0beta5 you can configure Nv2 in the Wireless menu.
Nv2 settings
nv2-qos sets the packet priority mechanism
frame-priority - manual setting that can be tuned with Mangle rules
default - default setting where small packets receive priority for best latency
Na tradução do google promete.....
Se alguem já estiver usando posta ai os relatos para nós avaliarmos os resultados....
Ivan Galves
Citação
