- Problema ao compilar
Olá pessoal,
Ao tentar instalar o Gtetrinet no Fedora core 2, obtenho a seguinte mensagem:
checking for pkg-config... /usr/bin/pkg-config
checking for libgnome-2.0 >= 2.0.0 libgnomeui-2.0 >= 2.0.0... Package libgnome-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libgnome-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libgnome-2.0' found
configure: error: Library requirements (libgnome-2.0 >= 2.0.0 libgnomeui-2.0 >= 2.0.0) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
Já tentei instalar o libgnome 2.0 e a mensagem é semelhante:
checking for esound >= 0.2.26 audiofile >= 0.2.3... Package esound was not found in the pkg-config search path.
Perhaps you should add the directory containing `esound.pc'
No package 'esound' found
checking for glib-2.0 >= 2.0.3 gmodule-2.0 >= 2.0.3 gnome-vfs-2.0 >= 1.9.16 libxml-2.0 >= 2.4.22 libbonobo-2.0 >= 2.0.0 gconf-2.0 >= 1.1.11 ... Package gnome-vfs-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gnome-vfs-2.0.pc'
No package 'gnome-vfs-2.0' found
configure: error: Library requirements (glib-2.0 >= 2.0.3 gmodule-2.0 >= 2.0.3 gnome-vfs-2.0 >= 1.9.16 libxml-2.0 >= 2.4.22 libbonobo-2.0 >= 2.0.0 gconf-2.0 >= 1.1.11 ) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
Alguem tem alguma idéia do que é pra ser feito?
Valeu a atenção!
Abraços,
Você tem que satisfazer todas as dependências.
Se der erro precisando de outra Biblioteca instale a outra e assim sucessivamente até atender todos os requisitos do pacote principal e dos outros pacote necessários.
Rafael
