- Dvd-Rw no Fedora 3
Dvd-Rw no Fedora 3
Salve galera,
Estou precisando intalar um drive de dvd para fazer Bkp nos servidores da empresa, mas antes disso estou testando na minha maquina. Estou tendado utilizar o cdrecorder, tranformei as pastas desejadas em .iso, identifiquei meu driver com o comando cdrecorder -scanbus e ele me retorna o seguinte:
[root@leandro sbin]# cdrecorde -scanbus
bash: cdrecorde: command not found
[root@leandro sbin]# cdrecord -scanbus
Cdrecord-Clone 2.01-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
Note: This version is an unofficial (modified) version with DVD support
Note: and therefore may have bugs that are not present in the original.
Note: Please send bug reports or support requests to http://bugzilla.redhat.com/bugzilla
Note: The author of cdrecord should not be bothered with problems in this version.
scsidev: 'ATA'
devname: 'ATA'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Using libscg version 'schily-0.8'.
cdrecord: Warning: using inofficial libscg transport code version (schily - Red Hat-scsi-linux-sg.c-1.83-RH '@(#)scsi-linux-sg.c 1.83 04/05/20 Copyright 1997 J. Schilling').
scsibus0:
0,0,0 0) *
cdrecord: Warning: controller returns wrong size for CD capabilities page.
0,1,0 1) ' ' 'CD56XI ' 'A4CH' Removable CD-ROM
0,2,0 2) *
0,3,0 3) *
0,4,0 4) *
0,5,0 5) *
0,6,0 6) *
0,7,0 7) *
scsibus1:
1,0,0 100) 'HL-DT-ST' 'DVDRAM GSA-4163B' 'A100' Removable CD-ROM
1,1,0 101) *
1,2,0 102) *
1,3,0 103) *
1,4,0 104) *
1,5,0 105) *
1,6,0 106) *
1,7,0 107) *
na hora de gravar eu dou o seguinte comando:
cdrecord dev=1,0,0 -v speed=8 -eject -data /nome_do_arquivo.iso
cdrecord: No write mode specified.
cdrecord: Asuming -tao mode.
cdrecord: Future versions of cdrecord may have different drive dependent defaults.
cdrecord: Continuing in 5 seconds...
TOC Type: 1 = CD-ROM
scsidev: '1,0,0'
scsibus: 1 target: 0 lun: 0
cdrecord: Success. Cannot open SCSI driver.
cdrecord: For possible targets try 'cdrecord -scanbus'.
cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
Alguem sabe como eu posso resolver este problema? Não precisa ser com o cdrecorder, pode ser qualquer programa, a unica coisa que eu preciso eh que seja em texo para poder ser feito via ssh.
Valeu
Dvd-Rw no Fedora 3
Dvd-Rw no Fedora 3
Não, soh tentei usar o cdrecorder. Tem algum tutorial sobre ele? Eu acho que meu problema esta em meu dvd-rw não estar sendo reconhecido como ide scsi.
Acho que tenho que subir o modulo ide=scsi, mas como fazer com que o driver seja reconhecido como scsi???
Dvd-Rw no Fedora 3
Galera
Me deram a dica de tentar gravar usando o seguinte comando
cdrecord -v -fs=16M speed=16 -data nome_do_arquivo.iso
Quando faço isso acho que o cd recorder assume que o dvd-rw esta em /dev/cdrom, mas no fedora ele monta por padrao em /media/cdrecorder
Alguem tem alguma ideia???
Valeu
fedora
estou com o mesmo problema aki mas no meu caso eu kero usar o apt no cdrom...mas o apt só reconhece se for no /mnt/cdrom...
bom como vc só ker gravar cds...tenta editar o /etc/fstab
vi /etc/fstab e trok la onde aparecer /media/cdrecorder coloca /mnt/cdrecorder ou /dev/cdrecorder
e naum eskece de criar o diretorio cdrecorder em /mnt ou /dev
espero ter ajudado e agora tb vou tentar gravar cds aki...mas minha briga mesmo é om o apt...se alguem puder ajudar ae!!!
Dvd-Rw no Fedora 3
Valeu galera!!!
Consegui gravar sem alterar nada!!! Simples mente usei -dev=/dev/ndc e rolou!!!
/media/cdrecorder eh tipo um link para o /dev/hdc! Agora ta blz!
